Thread: 3.0 TDI egr correction vcds
Hybrid View
  1. 3.0 TDI egr correction vcds
    Sep 2008
    Hi folks
    I am trying to "turn down" / reduce the operation of the egr for my ccwa engine, I can't find a specific documented process for this engine however have the steps in vcds that have been documented for other TDIs
    Engine - enter code 12233 - adaption - channel 3 or in my case egr correction, this is where it advises to change the value to 33768 which should equate to 370mg/h, my problem is that the max value this field will take is 50 and is displayed as 50mg/stroke
    Does anyone know what this means and how I can successfully reduce egr operation to a minimum ? I do intend to have it mapped out at a later stage as part of remap and DPf removal but getting intermittent insufficient flow error so wanted to try this for now
  2. Re: 3.0 TDI egr correction vcds
    46 Post(s)
    Insufficient flow means it's blocked, take it off and inspect the inside and clean if necessary.
  3. Re: 3.0 TDI egr correction vcds
    Sep 2008
    Thanks Chris I know its a job I have been dreading to be honest and one I intend to undertake as part of a wider post egr delete inlet manifold clean up! Just wanted to reduce egr operation in vcds in the hope that if it isn't active as much as intended if may be trigger the insufficient flow errors (lots of maybes I know) in anycase there does seem to be adjustment of the egr in vcds I'm just unsure of the values does anyone have an idea?
  4. Re: 3.0 TDI egr correction vcds
    Sep 2008
    *may not trigger
  5. Re: 3.0 TDI egr correction vcds
    Apr 2012
    Aylesbury, Bucks
    Quote Originally Posted by WOLFSBURG-PD View Post
    You probably already know but dpf deletion is now an MOT failure pint. (assuming you're in the UK of course)
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  6. Re: 3.0 TDI egr correction vcds
    Sep 2008
    Was thinking of getting a blocked dpf and gutting it then replace on mine
  1. Mileage correction
    By manity in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-08-2013, 11:57 PM
  2. EGR troubleshooting with VCDS
    By mongs in forum VCDS - Help Requests
    Last Post: 27-06-2013, 11:54 PM
  3. Colour correction
    By urbanaspect in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-11-2010, 09:43 PM
  4. TDI PD 100(ATD)-altering egr settings with vcds
    By ALIN in forum VCDS - General Questions
    Last Post: 02-06-2010, 07:14 PM
  5. Caddy Mileage Correction.
    By JVERBSON in forum The Commercial Range
    Last Post: 17-02-2008, 07:48 PM
