Thread: A4 Avant Front suspension clunk/click
  1. A4 Avant Front suspension clunk/click
    Jun 2014
    newport, s wales
    hi
    Probably been raised before
    I have a 2003 TDI A4 Avant
    I've recently heard a small clunk/click when reversing onto my drive
    I've checked all areas in front suspension (nearside) with no obvious reasons seen.
    also noted a slight grating noise when steering away from kerb at low speed.
    any pointers would be appreciated.
    thank
  2. Re: A4 Avant Front suspension clunk/click
    Sep 2014
    St. Louis Missouri
    Rear differential, rear end gears or bearing. Check fluid and smear on paper and shine a light to check for shavings... that would be my first thing.
  3. Re: A4 Avant Front suspension clunk/click
    6 Post(s)
    Quote Originally Posted by babygirl25stl View Post
    There's no mention that this is a quattro, rather it's a conventional 2WD drive car.
    My advice, raise car and grab front wheels at 10-to-2 position and check for lateral movement. Could be a bearing but you would hear wheel rumble or whine at 40mph. More likely to be split CV boot and worn CV joint which will click at full lock. Spin wheel and listen for ant tell-tale friction noise.
    Other contenders are worn tie-rod end or upper control arms. What's the mileage?
    2017 A4 Allroad Quattro Sport 3.0 TDI 272PS, (59k)
    2016 BMW i3 REx (80k)
  4. Re: A4 Avant Front suspension clunk/click
    Sep 2014
    cumbria
    Strutt top bearings i would think by the sounds of the symptons i could be wrong i useuaĺy am according to mrs!!!!
  1. 2004 Audi A4, front suspension clunk FIXED!
    By AliBailey88 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-07-2012, 09:44 PM
  2. Front end clunk- steering or suspension
    By john493 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 23-08-2011, 09:07 PM
  3. A4 Avant front suspension
    By Oggi1808 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2009, 06:54 AM
  4. Suspension Clunk
    By Pipeline in forum Bora - 1998 - 2005
    Last Post: 15-02-2009, 03:32 PM
  5. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
