Thread: Misfire after cambelt change on a4 3.0 petrol ASN
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    Just bought this audi a4 2003 3.0 Quattro auto. Took it to my local garage to replace cambelt on it because it was due for one.. ,So they done it and now got misfire on cilinders 4,5,6, it is very slight and only noticeable on idle, also its running quite hot I think temperature gage sits on 90, but vcds shows 104
    Done a scan and got this:
    Friday, 03 October 2014, 19:34:11.
    VCDS-Lite Version: Release 1.2
    Control Module Part Number: 8E0 909 559 H
    Component and/or Version: 3.0L V6/5V G 0003
    Software Coding: 0011751
    Work Shop Code: WSC 63351
    VCID: 3A07B1EB3547
    4 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal
    16688 - Shareware Version. To Decode all DTCs
    P0304 - 008 - Please Register/Activate
    16690 - Shareware Version. To Decode all DTCs
    P0306 - 008 - Please Register/Activate
    16689 - Cylinder 5: Misfire Detected
    P0305 - 008 - Implausible Signal
    Any help on this would be great
    Thanks in advance
  2. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Pembrokeshire
    22 Post(s)
    now then, how did they fit the belt, did they use the correct timing tools or did they not ?
  3. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    Not to sure about tools he used, he done a cambelt on rs6 and b6 2.4 v6, but not a 3.0 v6, do you think its timing issue?
  4. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    Also there is a lots of pressure in my coolant tank
  5. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    is it safe to drive it back to him? he is about 10 miles away?
  6. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Pembrokeshire
    22 Post(s)
    pressure in coolant and a misfire on one bank is indicative of a a head gasket failure. i would not be driving it anywhere. get the aa or whoever out or get it towed to him but for goodness sake don't drive it.
    a misfire alone on one side would sound like the cam is out of timing, but the coolant pressure adds another dilema.
  7. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    could it just need a correct bleeding? because he installed a genuine kit from tps with water pump, car was running perfect before it went into garage
  8. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Pembrokeshire
    22 Post(s)
    it could yes, but i doubt it, they bleed themselves. if it went in running correct,get on the blower to him and tell him you want it running right now. things do go wrong, crs do throw other faults whilst at garages but mechanics do also make mistakes. its how these mistakes are handled that count. tell him whats up and he should sort it out for you.
  9. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    I only done 15 miles in it since picked it up last night, definitely taking it back.. Thanks for your help, will update on this then get it back.
  10. Re: Misfire after cambelt change on a4 3.0 petrol ASN
    Aug 2011
    fakenham
    Just bled it right and there is no pressure in cooling system no more, noticed engine management light flashed few times..
  1. Engine misfire(2006 A4 petrol)
    By BTW in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-06-2014, 12:08 PM
  2. Help Needed Please 03 V6 ENG CODE ASN Misfire
    By Pdlk24 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-05-2014, 10:26 PM
  3. 2.5 petrol T4 misfire
    By Bdog in forum The Commercial Range
    Last Post: 13-01-2010, 11:24 AM
  4. MISFIRE 2006 A6 2.4 SE V6 petrol
    By jetstuff in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-03-2009, 04:08 PM
  5. Opinion on Cambelt change interval for a 1.8T Petrol MK2
    By The Hofmeister in forum Alhambra
    Last Post: 04-10-2007, 12:12 PM
