Thread: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
Results 1 to 9 of 9
  1. A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Hi All i need some help.
    My 2006 56 plate 3.0 QUattro TDi Aant had the dreaded zero Fuel problem when i brought it two years ago, but went away until 3 weeks ago. i thought may as well bite the bullet and do the loom fix. i tried it with scotch locks and it made no difference. so 2nd attempt was solder the wires and shrink wrap.
    this fixed the problem and i now have a working Gauge for the 1st time in 3 weeks.
    i filled the car and got to 500 miles 1/4 tank left. it started to miss fire and glow plug warning flashing. i pulled over and the diesel line was full of white froth. so i guessed out of fuel.
    luckily there was a fuel station on that road.
    put £10 in as i didn't want to have too much in when i opened it up later.
    i was 20 miles from home and it started to misfire again so i put another 5 litres in.
    i opened the drivers side sender and the fuel was almost to the point of spilling out. but only thing i could see was the black pipe from the passengerside was to the front of the in tank pump, so i moved it behind as it would be deeper in the tank. (Does this just sit in the tank? or should it connect to soething?)
    i opened the passengerside and it was empty, just a few mm on the bottom.
    there are no Faults in the Instrements so i guess Gauges are fine espeially as there was so much fuel in the tank.
    i also ran the car with the drivers side closed back up, the intank pump is working you can hear it sucking/buzzing away.
    So Why would it run out with so much fuel in the tank?
    what should i be looking for?
    Any help please.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Nov 2012
    Somerset UK
    Kidney shaped tank 80l just like all 3.0's am guessing, you'll probably need to buy the wiring repair kit that ensures that both sides are level, from memory it was £28.
    Am unsure if there's another pump in the passenger side but am guessing not if it was empty and you didn't see anything?
    Do a forum search as I did list the part no on one of the threads, sounds as if you're competant enough to fit yourself, must be a complete mare knowing you've half a tank but you're running out of fuel
  3. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    There should be no floating pipe from the suction jet pump. One pipe connects to the cover with a union nut and the other is located in through the top of the pump. Odd that the car stops. It could he the the floating pipe ( return from the suction jet pump ) is frothing up the deisel in the baffle tank and you are sucking it into the main fuel supply. Regards Peter
  4. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Dec 2007
    44 Post(s)
    Quote Originally Posted by MarkTM View Post
    Cheers But i have fixed the loom, there are no DTC's now.
    the repair kit would make no odds as i have soldered the wires.
  5. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Dec 2007
    44 Post(s)
    Quote Originally Posted by Peter D View Post
    yeah i have 3 pipes coming to the top of the sender / top section, one is supply out one is return one is a clear pipe to other side.
    i have a black pipe loose it doesnt have a clip or fast connector on it. where does this go?
    on the suction pump there are 3 holes on top, two are for the locating pegs on the top unit and a 3rd bigger hole, does it push in there?
  6. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Jul 2013
    76 Post(s)
    wrong post so deleted.
    Dan
    2009/2010 2.0 TDIe SE
  7. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Dec 2007
    44 Post(s)
    Well after an eventful drive home last night i have put the black pipe that was loose through a round opening on top of the intank pump unit as this always seems to be full of fuel, i guess this sucks and fills from the lowest point. so far i have driven to work with no more fuel added and its 25 miles, i want to run it to zero miles and fill it so i can restore my confidence with the tank range.
  8. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Jun 2020
    Great Britain
    Hi Peter !!Do you have any drawing on how and where this pipe should be connected? I have the same problem
  9. Re: A6 C6 3.0 Quattro Runs out of fuel at 1/4 tank
    Oct 2021
    leeds
    Me too - Anyone??
  1. 2.5tdi Quattro In Tank Fuel Pump
    By aliw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-03-2012, 08:20 PM
  2. Question Car runs out of fuel at 1/4 tank
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-02-2012, 01:48 PM
  3. Question What is the fuel tank capacity of an A4 Avant 1.9 TDI Quattro?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-01-2010, 04:44 AM
  4. A6 TDi Quattro Runs out of Diesel at half a tank!
    By dean warren in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-05-2009, 09:46 AM
  5. 2.8 Quattro Fuel Tank Level Sensor
    By SHAZA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-03-2008, 02:31 PM
