Thread: Audi a3 8p 2.0tdi bkd central lock
Results 1 to 10 of 20
  1. Audi a3 8p 2.0tdi bkd central lock
    Oct 2014
    TAUNTON . SOMERSET
    Another problem is: Key fob won't work. Need to press xx times(if u lucky) to lock/unlock. Even after reprograming with vcds still same. Cleaned fob with electrical cleaner no change. New battery no change. When programing with vcds car blinks. Later when you check in mb not remember which page but when you keep pressing fob its shows not ok not ok not ok in all fields. Also have fault codes for alarm horn no signal and passenger side safe/lock implausible signal. Also when unlock car with key motion sensor is trigered and indicators blinking till i put key in ignition on. Currently disabled motion sensor to stop blinking while trying enter the car. How to fix? Thanks for reading
  2. Re: Audi a3 8p 2.0tdi bkd central lock
    Near Blackpool
    48 Post(s)
    Just had same happen to my fob although it's gone totally, apparently chips go in them and they permanently say not ok each time. Buy a second hand fob and move RF glass tube over
  3. Re: Audi a3 8p 2.0tdi bkd central lock
    Oct 2014
    TAUNTON . SOMERSET
    But when i reprograming sometimes its works but need to press so many times.so u think is fob not central lock module?
  4. Re: Audi a3 8p 2.0tdi bkd central lock
    Near Blackpool
    48 Post(s)
    Can only tell you mine registers fine or lights flash and then says not ok each time after.
  5. Re: Audi a3 8p 2.0tdi bkd central lock
    Oct 2014
    TAUNTON . SOMERSET
    U fix yours?
  6. Re: Audi a3 8p 2.0tdi bkd central lock
    Near Blackpool
    48 Post(s)
    Yeah new key
  7. Re: Audi a3 8p 2.0tdi bkd central lock
    Oct 2014
    TAUNTON . SOMERSET
    New or second hand? Where u buy? How much? Thanks
  8. Audi a3 8p 2.0tdi bkd central lock
    Near Blackpool
    48 Post(s)
    Dealer £220 nearly dropped the phone, so got a secondhand one off eBay exact part number £27 and just changed glass transponder chip over and reprogrammed central locking
  9. Re: Audi a3 8p 2.0tdi bkd central lock
    Oct 2014
    TAUNTON . SOMERSET
    Ok i will fish for fob then. Where u find par nr? What another details i need to not to forget?
  10. Re: Audi a3 8p 2.0tdi bkd central lock
    Near Blackpool
    48 Post(s)
    Just part number under the key when you flip it out in small white writing
  1. Audi a3 8p 2.0tdi bkd turbo
    By Martynas26 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-10-2014, 11:28 AM
  2. over boost issues on 2006 A3 2.0TDI (BKD)
    By john1109 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-07-2014, 01:47 PM
  3. Need new bkd engine 2.0tdi
    By Themaddoc in forum 2.0TDi - Engine
    Last Post: 03-07-2014, 01:17 PM
  4. 2.0tdi bkd turbo not spooling on startup
    By patmcnamara78 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2011, 11:03 PM
  5. 2.0TDI 140PS BKD Idle Problem!
    By gtitdi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-05-2010, 07:58 PM
