Thread: Heated Rear Screen causes loss of DAB signal
Results 1 to 10 of 17
  1. Heated Rear Screen causes loss of DAB signal
    Apr 2014
    Kenilworth UK
    I've had my BE for 3 weeks now and just noticed this morning that when I turn on my heated rear window my DAB signal drops out.....I tried it on the way home from work and it still dropped out but only occasionally, could it be due to a low DAB signal strength being somehow blocked when the heater element (which I believe incorporate the ariel) is switched on?
    I wish it wasn't intermittent... I fear it's gonna be a bugger to fix.
    Anyone else had this?
    PS the reason I think I never noticed this before was I have been listening to an ipod connected to the MMI.
    N16E
  2. Re: Heated Rear Screen causes loss of DAB signal.....
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by N16E View Post
    N16E
    Assume you have a saloon. Sounds like the aerial amp may be faulty, definitely a trip to the dealer to get it sorted.
  3. Re: Heated Rear Screen causes loss of DAB signal.....
    May 2014
    Bath, UK
    Sounds like some interference. FYI though, the DAB antenna is in the quarter/side window, and not the actual rear window.
    Assuming you're in warranty, I'd just give it to the dealer to fix.
    If you feel like tinkering... if you go into the Green Hidden MMI menu, you can view the tuner's signal level and then watch what happens when you turn the heater on.
  4. Re: Heated Rear Screen causes loss of DAB signal.....
    Apr 2014
    Kenilworth UK
    Quick Update
    New Rear Window fitted = Problem solved
    btw....Engine and gearbox software both updated.
    I had complained about the car failing to pull away quickly at roundabouts (when still rolling) and was told this was due the "adaptive" gearbox not changing down from 3rd, anyhow not really tested it out in anger yet, but the car does seem even smoother.
    Anyone had issue with the track information going missing or the system dropping out when connecting IP5 via blutooth?
    N16E
  5. Re: Heated Rear Screen causes loss of DAB signal.....
    Apr 2014
    Liverpool, England
    I have this too! It also makes my FM stations crackle when the heated rear screen is on!
  6. Re: Heated Rear Screen causes loss of DAB signal.....
    Apr 2014
    Kenilworth UK
    Yes, my dab dropped and my FM crackled. It does sound like you have the same or similar problem, how old is your car?
    Btw before my screen was changed I noticed one of the heater elements was broken (one line only partial cleared)
    Good luck getting it sorted.
    N16E
  7. Re: Heated Rear Screen causes loss of DAB signal.....
    Apr 2014
    Liverpool, England
    Mine is an Ultra BE saloon, 14 plate registered July.
  8. Re: Heated Rear Screen causes loss of DAB signal.....
    Nov 2014
    United Kingdom
    I've noticed exactly the same issue. At first I thought that it may be due to the damp and miserable weather that we are experiencing. thankfully I checked the forum and found that others were having the same problems. Spoke to the dealer today and booked the car in for investigation work. Just covered 1800 miles and the receptionist stated that it "should " be covered under the manufacturers warranty!
  9. Re: Heated Rear Screen causes loss of DAB signal.....
    Apr 2014
    Norton, Daresbury UK
    mine is booked in tomorrow to investigate as I lose DAB and FM crackles when screen is enabled - also notice 3 elements broke on drivers side
  10. Re: Heated Rear Screen causes loss of DAB signal.....
    Nov 2014
    United Kingdom
    Had mine in at the dealers a week last Monday (24th November) and still waiting for a response from them. They contacted me to tell me that I had caused the damage by using a cleaning product on the glass that has corroded the terminals! therefore it won't be covered under warranty. Told them that as the car is only 4 months old I haven't had chance to clean the glass yet and if I did I would be using the Audi branded cleaning kit that was given to me when i picked up the vehicle.
    Collected the vehicle later that day and the service manager was still trying to get a response from Audi UK. I look forward to seeing how you get on with yours.
  1. A6 Heated Rear Screen - radio Interference DAB and FM
    By wrc555s in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-11-2014, 11:38 PM
  2. Heated rear screen
    By greenkeeper in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-11-2013, 11:31 AM
  3. A6 Saloon - Heated Rear Screen
    By nicktooley in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-11-2010, 03:57 PM
  4. Heated rear screen not working help!
    By donbizzle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-12-2009, 10:02 AM
  5. Radio going with heated rear screen
    By andyroo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2008, 09:28 PM
