Thread: Loss of power above 3k revs
Results 1 to 9 of 9
  1. Loss of power above 3k revs
    Sep 2007
    East Sussex
    As the title says get above 3k in any gear and it almost sems as though the turbo cuts out, pull over turn of ignition and then start up again and all is ok. The car is a 52 plate 1.9tdi 100bhp model, can anyone give me some help please
  2. Re: Loss of power above 3k revs
    132 Post(s)
    1980 Post(s)
    A fault code report should show a boost pressure error which is usually down to the MAP (Manifold Absolute Pressure) sensor sticking at around 2880 mBar, So a fault code scan first.
  3. Re: Loss of power above 3k revs
    Aug 2007
    Mine is doing the same, power is great under 3k and beats most things off the lights but stuggles to do over 95ish (not that I do those kind of speeds!!)
    Is this a cheap fix, mine has been on the computer, it didn't come up with any errors.
    Any help would be much appreciated.
    Ta Lee
  4. Re: Loss of power above 3k revs
    132 Post(s)
    1980 Post(s)
    What is yours Jay? Has it been modified?
  5. Re: Loss of power above 3k revs
    mine was doing the same, until i replace the MAF (mass air flow meter) and it felt like a new car, apparently they are a common fault and need replacing every 2-3 years, try it mate you'll probably be very surprised.
  6. Re: Loss of power above 3k revs
    Aug 2007
    Mine is a GT TDI 110, year 2000, its not been modified, last owner was a middles aged women, its really weird, under 3k it feels great, the MAF was checked and came out as working fine, the only fault that came up was boost pressure valve but that was done under warranty, a couple of months on the problem is back, and now the car is out of warranty. Do you think the garage could have bodged it until the warranty ran out?
    If anyone can help it would be much appreciated, sticking it on the machine at a garage I know will cost me £50, don't want to shell out that if it comes up with nothing.
    Ta Lee
  7. Re: Loss of power above 3k revs
    132 Post(s)
    1980 Post(s)
    It is nearly impossible to accurately check the MAF but those symptoms don't match a typical failed MAF. However, with almost all TDI running problems that show no codes, I usually replace the MAF with a genuine dealer supplied unit first-DO NOT BUY A MAF FROM ANYWHERE EXCEPT A VW DEALER. I know a scan is going to cost (a typical independent would charge around £25) but it must be done first or you will just end up chasing your tail around in circles until you give in and get it done at which point you my get a relevant fault code.
  8. Re: Loss of power above 3k revs
    Aug 2007
    Thanks, I'll get it scanned, as soon as I do I'll post the results.
    Ta Lee
  9. Re: Loss of power above 3k revs
    132 Post(s)
    1980 Post(s)
    It is very rare to get a MAF come up as a fault so we usually use the "no codes, no power, new MAF" method.
  1. Polo M reg 94' Loses power in higher revs
    By adamrob69 in forum Polo - Derby - Lupo - Fox
    Last Post: 01-03-2009, 09:11 PM
  2. power loss
    By john grout in forum Passat - Archive Topics
    Last Post: 21-01-2008, 01:14 PM
  3. Bora PD115 power not peaking at correct revs
    By Jugga in forum Bora - 1998 - 2005
    Last Post: 12-08-2007, 05:42 PM
  4. A6 lacking power aver 2500 revs
    By critterman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-03-2007, 02:47 PM
  5. loss of power
    By Lofty in forum 80 - 90
    Last Post: 22-07-2006, 06:28 PM
