Thread: 2.0l tdi pd fault finally found. please read
Results 11 to 20 of 25
  1. Re: how do i fix this?? please help
    Aug 2014
    essex
    Update....broken tappets.. pics below
    Ive managed to remove all exhaust tappets out of the arms which is a very fiddly job. But it is possible.
    Firstly you must block oilways to sump icase of debris.
    Also cover valve springs to stop debris going in them.
    Compressed air in tiny hole on top of arms fires tappets out.
    I have 4 broken springs!!
    All my inlet tappets are still adjusted up solid after another week without oil.
    there is no mechanism in these tappets. Oil just gets pumped into the arms and fills up the tappets. Mine are collapsed and worn slightly on the wobbly bit so suspected timing issue causing valve contact or oil starvation causing dry running.
  2. Re: how do i fix this?? please help
    Aug 2014
    essex
    Video below shows arms with limited access for tappet removal and inlets still pumped up.
    Audi a4 2.0 tdi tappet failure hydraulic lifter b7: Audi a4 2.0 tdi tappet failure hydraulic lifter b7 - YouTube
  3. Re: how do i fix this?? please help
    Dec 2006
    Stoke/Congleton
    Do them cam bearings look like they are down to the brass/copper . maybe oil starvation has been a problem.
  4. Re: how do i fix this?? please help
    Aug 2014
    essex
    Well its had a new turbo by the looks of it so im wondering if oil pump failed in the past.
    I just dont know how to check its recieving good pressure in the head now?
  5. Re: how do i fix this?? please help
    Dec 2006
    Stoke/Congleton
    A easy check is start it with the cover off, and you should get covered in the oil squirting out.
    The only other thing is to check the oil pressure with a gauge attached to where the oil pressure switch goes at the bottom of the oil filter housing.
  6. Re: how do i fix this?? please help
    Aug 2014
    essex
    I need to try locate some tappets. They are not available on their own it seems.
    i was hoping there was a way of checking if oil is coming out of the tappet arms. Once tappets are in the arms i cant see if oil is coming out of them because the tappet stops the oil coming out.
    i almost need to run it without tappets to see
  7. Re: how do i fix this?? please help
    #17
    Dec 2006
    Stoke/Congleton
    http://www.germanautopartsdirect.co....duct_info.html
    Don't know if that's it but you have to go through the Febi stuff page by page as it doesn't seem to work on search
  8. Re: how do i fix this?? please help
    #18
    Aug 2014
    essex
    Its not that type but i have emailed them to ask. Many thanks
  9. Re: how do i fix this?? please help
    #19
    Aug 2014
    essex
    No joy with tappets from anywhere unless i buy complete with arms at £190 pattern!
  10. Re: how do i fix this?? please help
    #20
    Dec 2006
    Stoke/Congleton
  1. I finally found a Le Mans!
    By Happybiker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-09-2013, 11:10 AM
  2. Finally found it... My new Car
    By Schmittster in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-02-2013, 01:27 PM
  3. Finally found my baby
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-08-2010, 04:42 PM
  4. finally found one
    By dansansome in forum Chat - Anything with wheels
    Last Post: 05-06-2008, 01:00 PM
  5. fault codes read + 1 found.
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2008, 07:11 PM
