Thread: Help please Turbo problems
Results 1 to 10 of 17
  1. Help please Turbo problems
    May 2009
    My car is an 02 A4 TDI 130 with 152k on the clock. Took it to England a few weeks ago and on the way up the M5 it lost power and spluttered black smoke everywhere. Intercooler was broke, limped it up the boat with no turbo and got it home. Replaced intercooler and still wasnt right so replaced EGR valve seemed to go ok apart from a noise from the turbo area which my friend a mechanic said was the wastegate and nothing to worry about. Wife just come home and car is running with no turbo again, showing error code 17965 when I scanned it. Anyone any ideas, is it the N75 valve that I've read about or is the turbo just done, if thats the case does anyone want to buy the car as I'm just about fed up with it. Thanks in advance for any replies,
    Mike
  2. Re: Help please Turbo problems
    Jan 2009
    Birmingham
    36 Post(s)
    Your turbo is overboosting and going in to limp mode most likely the turbo vanes are clogged with carbon you need a new turbo or recon unit you can check to see if the actuator on the turbo is moving freely by using a hand held vac pump
  3. Re: Help please Turbo problems
    May 2009
    Quote Originally Posted by arman123 View Post
    Thanks for the reply , is that the noise Ive been hearing then ? I checked the turbo a few days ago when changin the Egr valve and it seemed fine no play and vanes were turning ok but i think your right and its fupped, listened to it again there and theres a very slight whistle which I dont think is a good sign. Is it worth taking the turbo off and cleaning it out?
  4. Re: Help please Turbo problems
    Jan 2009
    Birmingham
    36 Post(s)
    You could have a go some people have used me muscle on the hot side of the turbo to remove the carbon the put it thorough the egr pipe to the hot side of turbo and let it sit a few hours and wash it out with some brake cleaner but if I were you I would just replace it with a good recon unit or better get your reconditioned.
  5. Re: Help please Turbo problems
    May 2009
    Ok thanks mate will start searching for who's best / cheapest for recon units, is the car ok to drive?
  6. Re: Help please Turbo problems
    Jan 2009
    Birmingham
    36 Post(s)
    To and from shops and local yes but any overtaking on motorway no it will be dangerous if it event to limp mode
  1. turbo problems
    By splasher in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-08-2009, 12:27 PM
  2. Audi 5000 Turbo/ Audi 200 Turbo problems
    By Rebl in forum 100 - 200 - Turbo - 100 S4
    Last Post: 14-06-2008, 11:52 PM
  3. Please Help A4 turbo problems
    By davea4123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-06-2008, 11:49 PM
  4. Audi 5000 Turbo/ Audi 200 Turbo problems
    Last Post: 06-06-2008, 10:44 PM
  5. Turbo problems ????
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2007, 03:58 PM
