I urgently need some help here please.
I recently retrofitted cruise control to my 2008 Audi A5, which went ok and I have been trying to activate cruise using the VAG COM and it wouldn’t.
I have done a scan on my car with ignition ON (car not started) and below are the results:
Chassis Type: 8T0
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 55
56 77
Mileage: 74350km/46198miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 1A0500
Shop #: WSC 06325 000 00000
VCID: 78F4F613CB5C68DEA3D-802D
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 011000
VCID: 39723317B0D6B1D69C3-806C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329F+087578950
Coding: 0005002
VCID: 4A907CDB25302A4E059-801F
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000101024
Subsystem 3 - Serial number: 0117.06.080000000100010283ÿ
Subsystem 4 - Serial number: 010283ÿ
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 208
Mileage: 74341 km
Time Indication: 0
Date: 2014.09.15
Time: 19:30:25
Freeze Frame:
Bin. Bits: 00110000 00000010
Bin. Bits: 00000000 00001010
Bin. Bits: 00000000 00000000
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0140
Revision: D0000000 Serial number: 0104.06.080513
Coding: 36060000
VCID: 428054FBDD00F20ECD9-8017
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 208
Mileage: 74334 km
Time Indication: 0
Date: 2008.02.08
Time: 00:00:11
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000162998
Coding: 260050914034AF010009000000005D5D001D43880001014100 0000
VCID: 2F660D4F7E926F66327-807A
Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160508 H11 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043002 Serial number: AUZ5ZBH8462179
Shop #: WSC 00000 000 00000
VCID: 2B5E195F8A8A13461EF-807E
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HFI0003J
Coding: 000032
VCID: 3D7A2707A4FE8DF6B0B-8068
Component: E221 - MFL H02 0003
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 11
Reset counter: 169
Mileage: 1048574 km
Time Indication: 0
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H29 0221
Revision: 00000000 Serial number: 8YJ1AK968
Coding: 2F07000002002600010000
VCID: 3B7E291FBAEA83C68EF-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E0860780BC
Coding: 000303
VCID: 499243D7E03621560C3-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 333FW087582159
Shop #: WSC 00048 210 91068
VCID: 3B7E291F7AEA83C68EF-806E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00003002 Serial number: 0111875325
Coding: 011B068200390400002000
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G
Component: DSP STD H08 0300
Revision: S2600000
Coding: 010101
VCID: 70E4CE33A32C309E6BD-8025
1 Fault Found:
02247 - Subwoofer (R148/R157)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 52
Reset counter: 164
Mileage: 66731 km
Time Indication: 0
Date: 2014.05.28
Time: 14:39:08
Freeze Frame:
Voltage: 12.20 V
Temperature: 18.0°C
Bin. Bits: 00000011
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 336F/087569753
Coding: 0000001
VCID: 31620B37A8A67996243-8064
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 D HW: 4F1 862 335
Component: BTA H11 1120
Revision: 00H11000 Serial number: 00000007579914
Coding: 0010021
VCID: 254AEF67EC6E2536C8B-8070
I am very confused here and I have looked only to dig out a solution but can’t seem to find any. Any help will be much appreciated.
