Thread: Washer Bottle Problems
  1. Washer Bottle Problems
    Rob58 Guest
    I have a 99 T Reg Passat Sport TDI 110 with a leak at the base of the windscreen washer pump mounted on the washer reservoir; it appears the seal has gone and needs replacing.
    At the risk of asking the most ridiculous question, can anyone advise how to undo and remove the pump as I cannot free it and do not want to force it lest I crack/split the washer tank/reservoir as well. Many thanks.
  2. Re: Washer Bottle Problems
    7 Post(s)
    Are you sure it is the pump seal ?
    I had a leak down there and it turned out to be a split pipe above, just that the water was running down so it appeared to the the pump.
    Anyway, to remove the pump, twist it about 45 degrees whilst pulling it from the bottle. It does take a good tug by the way.
  1. Rear washer jet?
    By AWH in forum Chat - Completely Off Topic
    Last Post: 01-11-2008, 02:40 PM
  2. Oil in header bottle
    By pauldpaddy in forum Passat - Archive Topics
    Last Post: 01-08-2007, 02:03 AM
  3. 02 A6 Washer Leak
    By akh747 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-07-2007, 04:00 AM
  4. Rear washer
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 25-05-2007, 04:41 PM
  5. A4 leaking washer
    By fredhew in forum Chat - Completely Off Topic
    Last Post: 01-03-2007, 12:48 AM
