Thread: AC belt coming off tensioner/roller
  1. AC belt coming off tensioner/roller
    Jun 2008
    I had a frayed AC belt on my '02 A6 tdi (AKE) and found no logical reason for failure except some serious grooves cut into the lower belt cover which made me think continued use and rubbing just wore it down in the end. Replaced belt and decided not to refit the cover as in current (poor) condition, looks like it would just contact the belt again. Tested it first and belt did move 1-2mm over the edge of the tensioner then reset itself when stopped. Checked torque as best I can in service position (I need front end completely off to get proper torque angle access).
    Drove 350km this am nice and chilly. On the return leg, no A/C at all, quickly found belt had come off the tensioner, but seemed intact (will investigate further).
    The other Aux belt also sits a little 'offset' on one of the rollers (it too frayed and cut into the cover a while ago). Is this normal? Is someting missing from the rollers/tensioner, like a cap that keeps the belt in line? I can't believe the purpose of the cover is to keep the belts on (see pic), so is something else wrong? thx2014-09-10 22.49.29.jpg
  2. Re: AC belt coming off tensioner/roller
    Pembrokeshire
    22 Post(s)
    a bearing or the tensioner has failed and is running at a silly angle, not quite straight, allowing the belt to run off.
  3. Re: AC belt coming off tensioner/roller
    Jun 2008
    ok thanks, so if the tensioner 'seems' ok, I guess it could be the crank or the AC pulley which is gone bad, will pull the front and check both...
  4. Re: AC belt coming off tensioner/roller
    Pembrokeshire
    22 Post(s)
    with the belt on and under tension, use your eye or use a straight edge to see which one is running not true to the others.
  5. Re: AC belt coming off tensioner/roller
    Nov 2011
    Duns Scotland
    11 Post(s)
    With regard to tensioner or pulley bearings going bad, with the belt off they should spin freely (by hand) and make little noise. If it is the aircon pulley, and you have a clutch type mechanism for engaging the aircon, then the clutch and then the aircon pulley can be removed. A local machine shop will press out the old bearing and press in the new for you. Check one of my posts on the subject to identify the supplier and replacement bearing number. When I came to do the cambelt changes on my 2002 Audi Allroad 2.5 AKE I found a sheared aircon belt, tensioner disintegrating and aircon pulley sound rough. All changed 22k ago and no problems.
  6. Re: AC belt coming off tensioner/roller
    Ayrshire, Scotland
    18 Post(s)
    For the large belt which does power steering, alternator, fan and a few rollers, it will be the tentioner pivot bearing bushes which are worn so the tentioner sits an an angle pulling the belt off the upper roller, you can tell if you hold the tentioner using the latge hex to retract it and if you can wobble it side to side,
    the small aircon belt must be the tentioner bearing also causing it to rub off,
    also note the belt cover must be fitted with 3 top hat spacers otherwise it will rub against the belts,
    i recomend to check and change the bushes for the large belt, tentioner pivot, they are not expensive but a front off job, it is not the actual roller bearing but the pivit point of the tentioner which wears, their are small very thin bushed sleeves you can replace as long as it has not worn through the casting, mine were bad at 90,000mls with the belt rubing through the cover,
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  7. Re: AC belt coming off tensioner/roller
    Jun 2008
    Quote Originally Posted by bagpipingandy View Post
    yes this caused my main Aux belt failure and replaced the bushes last year. It looks like all pulleys/rollers were last replaced about 65k ago, so I think I'll just have to check and replace the lot when I do my toothed belt next (due now anyway).
    Cover spacers were in place so guess some wear in bearings over time has led to slippage.
  1. Was my cam belt idler roller missing????
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-10-2010, 02:40 PM
  2. 1.4 belt tensioner
    By dok in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2010, 12:13 PM
  3. vibrating noise & belt slip on full lock- serpentine belt tensioner?
    By VtecJunkie in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-12-2009, 04:39 PM
  4. Kinda urgent - replacing belt tensioner, alternator pulley, and belt.
    By farmamick in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
  5. Question Metal timing belt roller replacement on GT TDi
    By mobitune in forum Golf MK4 - 1999 - 2004
    Last Post: 17-06-2008, 08:04 PM
