hi,
any help would be appreciated,
battery was getting flat on my 2007 a3 1.9 diesel after cranking (after engine change) so went to jump it but now will not crank !
battery now fully charged but no power to solenoid on starter upon cranking position on key
done a bit of research appears audis will crank over even with immobilizer probs unlike other makes (as i initially thought this was the problem)
do these have a starter relay ?
are the ignition switches prone for failure as this is the only thing that would make any sense even though its only done 60k
no fault codes showing
thanks in advance
