Thread: Rear lights on 1995 ford escort!!
Hybrid View
  1. Rear lights on 1995 ford escort!!
    Nov 2006
    Sheppey, Kent
    Hi Guys,
    I know this is probably not the best place in the world to be asking a question about a FORD but i have this old escort which we use as a run around to save getting the Audi mucked up with old boxes etc.
    The problem is the rear lights have just stopped working, along with the dashboard lights. What is puzzeling is that the break lights/Indicators/reverse lights all work fine. It wopuld appear that quite simply when i turn the lights on at night the front lights all work but rear night driving lights and dashboard lights do not function. I have checked all the fuses which appear ok, and yes i even checked the bulbs.
    Can any one suggest what else i might check to solve what is no doubt a simple problem "I hope"
    Marcus
  2. Re: Rear lights on 1995 ford escort!!
    Dec 2006
    Manchester
    Quote Originally Posted by marcus View Post
    Hi Guys,
    Marcus
    I've seen this problem on the ford escort many times before, and it has a simple and quick solution.
    A match in the fuel tank normally does the trick
    Only joking, although the escort i once owned was the worst car ever, being only a 1.3 is was severly underpowered.
    I think your problem could be the stalk itself. Probably around a £10 from a local scrappie.
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: Rear lights on 1995 ford escort!!
    Nov 2006
    Sheppey, Kent
    Thanks Nick,
    Probably the match will be the end result!!!, but surly if it was the stalk itself neither front or back lights would work, as i would assume they are both on the same circuit as with the dash lights!!!.
    Other simple answer i suppose is dont drive at night!!!
    mark
  4. Re: Rear lights on 1995 ford escort!!
    Oct 2005
    Check the wiring to the rear lights, remove the bulbs and rub the contacts with some wire wool, forget to put the handbrake on when parking uphill.
  5. Re: Rear lights on 1995 ford escort!!
    Nov 2006
    Sheppey, Kent
    Cheers, tried that already,
    Looks like definatly handbrake off and match in the tank!!!
  1. 1995 A6 Dash lights
    By easytreasure in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 14-09-2007, 06:00 PM
  2. www.vagcat.com - is there a Ford equivalent?
    By Ben in forum Chat - Anything with wheels
    Last Post: 16-07-2007, 10:23 AM
  3. 2001 Ford Focus 1.8 Zetec
    By Pimped-Passat in forum Chat - Anything with wheels
    Last Post: 31-03-2007, 07:44 PM
  4. Audi A4 (2.6 V6 1995 N) Dash Lights
    By Toucan in forum Archive posts
    Last Post: 14-03-2006, 01:09 PM
