Thread: A6 Caliper Slider Bolts
Results 1 to 10 of 15
  1. A6 Caliper Slider Bolts
    Nov 2008
    Hi guys,
    I have been told need to replace the caliper slider bolts in my 2007 A6 Avant to stop the annoying clunk under braking. I have done the usual google search and have not got anywhere with finding some. Does anybody know where I can get some from?
    Thanks!
  2. Re: A6 Caliper Slider Bolts
    Nov 2012
    Somerset UK
    Who told you?
    Have you tried a main dealer (although suspect you can only buy the whole assembly)?
  3. Re: A6 Caliper Slider Bolts
    Jun 2009
    Bexleyheath, England
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
    1 1 0
  4. Re: A6 Caliper Slider Bolts
    Jul 2013
    76 Post(s)
    try these
    Bigg Red
    if the site is being updated just ring them.
    dan
  5. Re: A6 Caliper Slider Bolts
    If you have FN3 front brakes then I suspect you have had the pads changed recently and the person that did it has not fitted the correct side in each caliper. There is an arrow on the inner pad that mus point in the direction of rotation of the wheel.
    If it does not then every time you brake there is a single 'Clunk' form the front brakes. Regards Peter
  6. Re: A6 Caliper Slider Bolts
    Nov 2008
    I have had the pads replaced recently but have now been told that it is the caliper sliders that are worn and they only come as part of the calipers etc from main dealers only. £1100 to fix!
    Not so sure myself...
  7. Re: A6 Caliper Slider Bolts
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by GT-ANDY View Post
    View the link that joedredd has posted in post 3 I think you'll find they are available on their own.
    View the data sticker either in your service log or spare wheel well for your brake system PR code, some tech data in this post Link:- Pads need replacing - would anybody recommend Pagid?
  8. Re: A6 Caliper Slider Bolts
    Pembrokeshire
    22 Post(s)
    did this noise start jut after you had the pads fitted ? i so, read peters post and get the pads put in the right way round.
  9. Re: A6 Caliper Slider Bolts
    You are not listening GT-Andy. Tell us what front calipers you have. Caliper slide pins in many calipers have do metal to metal contact and do not wear. Regards Peter
  10. Re: A6 Caliper Slider Bolts
    Nov 2012
    Somerset UK
    GT-Andy
    If I am reading this thread right they (Peter & Zollaf) are advising that your brakes may not have been reassembled correctly after your pad change which has led to your current issue.
    Also, if it's the same place that's now advising you that new slider pins are needed, they should be made aware that possibly their error and responsibility to put right.
    1 1 0
  1. Caliper mounting bolts on '98 Passat
    By matpj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-01-2014, 10:59 AM
  2. Audi a3 rear brake caliper slider bolts - replace?
    By GMW43 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-09-2013, 03:24 PM
  3. Please Help Caliper slider bolts on an FS III unit(2009 polo 1.4tdi)
    By bloostar in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2013, 06:57 PM
  4. Question Bolts for brake caliper '7mm Hex bolts'
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2012, 07:59 PM
  5. Caliper Bolts
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-05-2007, 07:55 PM
