Thread: Loose door bolts
  1. Loose door bolts
    Mar 2011
    Uk
    The passenger door hing as been making a little bit more noise than normal over the past month or two so I've greased it up but it made no difference. Today when the wife went into the shops I stayed outside and looked at the door. I found the bolts was loose and as the door was opening and closing the hing was moving. I tighten the bolts up and the noise has gone away.
    Has anyone else had this or am I just unlucky
  2. Re: Loose door bolts
    Aug 2014
    derby
    Quote Originally Posted by man le-mans View Post
    When I bought my A6 ('11 plate, 3 yrs old at time of purchase) about 6 months ago, I found that the bolts for the drivers door hinge were loose, tightened up & been fine ever since, all other door hinge bolts were fine (physically checked that they were torqued up)
    No evidence that the doors been off previously to suggest anything , just going to keep an eye on it .....
  3. Re: Loose door bolts
    134 Post(s)
    2007 Post(s)
    The 4F A6 was not as well built as the previous models with many build quality issues.
  4. Re: Loose door bolts
    Mar 2011
    Uk
    It's a 11 plate and I got it new ( well ex demo ) so I know it's never had any repair done.
    just find it odd that bolts would work loose and now think what else hasn't been tighten correctly
  5. Re: Loose door bolts
    Mar 2011
    Uk
    I never knew that was this because they was built else where or was there just problems with the design
  6. Re: Loose door bolts
    134 Post(s)
    2007 Post(s)
    It is a lighter design made to cost less to produce, all manufacturers are pulling money and weight out of their designs to increase profits and reduce Co2 emissions.
  7. Re: Loose door bolts
    Aug 2011
    Meath
  1. Loose Door Handle
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2016, 05:12 PM
  2. Wheel bolts coming loose !!!!
    By Shadow CC in forum Passat CC
    Last Post: 22-09-2011, 05:04 PM
  3. Loose door handle
    By gaz1965 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-07-2010, 01:44 PM
  4. MK IV loose door barrel
    By powershandyman in forum Golf MK4 - 1999 - 2004
    Last Post: 12-02-2010, 05:32 PM
  5. Door handle has become loose.
    By vma99r in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-09-2009, 11:09 PM
