Thread: camshaft failure passat 2004 tdi 116k
Results 1 to 9 of 9
  1. camshaft failure passat 2004 tdi 116k
    Aug 2008
    Bedfordshire
    Hey guys so iv replaced injector loom thinking that was my problem but now it seems like it more than that
    Anyway can someone recommend where to buy the parts and possibly part numbers of everything i need please. Is it ok just to buy from fleabay? I was thinking of buying
    Camshaft
    Lifters
    Bearings
    Timing belt
    Water pump
    Is there anything else i should replace? Any help will be appreciated thank you.
    Ps. A friend is going to do the work on car
    Here is a link of the noise its making after loom replacement
    Watch "Vw passat tdi 2004 116k camshaft failure" on YouTube
    Vw passat tdi 2004 116k camshaft failure: Vw passat tdi 2004 116k camshaft failure - YouTube
    when i let go of what i am....i become what i might be
  2. Re: camshaft failure passat 2004 tdi 116k
    Aug 2011
    Meath
    Get a proper diagnostic scan before you start pouring money into it. Look on the map for someone near you with VCDS VWAF User Location Map - VCDS - Google Maps
    1 1 0
  3. Re: camshaft failure passat 2004 tdi 116k
    Aug 2008
    Bedfordshire
    Map doesn't seem to be working
  4. Re: camshaft failure passat 2004 tdi 116k
    Aug 2011
    Meath
    Quote Originally Posted by 786sam View Post
    you'll have to pm a mod
    1 1 0
  5. Re: camshaft failure passat 2004 tdi 116k
    Pembrokeshire
    22 Post(s)
    if it is the camshaft, which it sounds like it could be, but course could be something else, which is why a proper diagnostic is a good idea, but if it is the camshaft, then this is what not using the right oil does to your engine. i try to tell people to use the right oil. some listen, some don't.
    2 2 0
  6. Re: camshaft failure passat 2004 tdi 116k
    Aug 2008
    Bedfordshire
    I agree zollaf but this was done by my teenage brother who was loaned the car before he bought 1.. he bought a new car, dropped this one off saying "thanx for lending it to me but something is ******! Lol
    Had the car since 20k bought in 2006.. the cars been too good to us so want to cherish every last breath it has
  7. Re: camshaft failure passat 2004 tdi 116k
    131 Post(s)
    1973 Post(s)
    When a PD 8v cam goes it makes a noise through the air cleaner intake which is hard to describe, a sort of ba ba ba ba beat that once you hear it, you know the next time. We are just doing the cam on a 2006 Golf 5 1.9 that had two failed lobes and we are using a tool steel cam from FAI, these are the only people I seem to be able to get a tool steel cam from and they are really nice people to deal with as well. Unless the supplier can guarantee the cam is tool steel, walk away! Cast iron cams are available and they snap! Fitting a new cam can be stressful on these. I am using the job to train a younger member of staff to do this sort of job, taking him forward from more mundane tasks of pads/discs/suspension/servicing he has spent the last year on and more into the internals of engines as to be honest we get far far less chance to do this these days as cars are so bloody reliable, either that or when they do go bang the costs are so high they are scrap. During this job I have showed him how these engines very badly wear their cam bearings (I will take a pic tomorrow) and another quite unnerving problem, how unbelievably tight a brand new cam goes in new bearings once you have bolted down the injector rockers arms. I showed him how that the torque required to break a new cam free in new bearings can exceeded the 100Nm torque applied to the centre pulley bolt and this can make setting up the cam timing quite a trial.
    1 2 0
  8. Re: camshaft failure passat 2004 tdi 116k
    Aug 2008
    Bedfordshire
    Very informative thank you so much. .. can you please check the video on youtube and see it its something you might have heard before? The airbox has been removed so may sound louder than normal...
  9. Re: camshaft failure passat 2004 tdi 116k
    131 Post(s)
    1973 Post(s)
    Prod me over this later.
  1. ABY/AAN Camshaft pulley key failure
    By skibruce in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 13-11-2013, 08:16 PM
  2. Audi B7 A4 2.0TFSI Quattro High Pressure Fuel Pump and Camshaft Failure
    By hal402 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2013, 10:31 AM
  3. camshaft failure
    By lionyo in forum Octavia
    Last Post: 23-08-2011, 01:00 PM
  4. Passat 1996 1.9 TDI CRANKSHAFT TO CAMSHAFT QUESTION
    By jill300268 in forum Early Passat Forum - Pre 97
    Last Post: 18-04-2008, 07:25 PM
  5. 2004 mk5 gt tdi turbo failure how common
    By t5psr in forum Golf MK5 - 2004 - 2009
    Last Post: 30-12-2007, 02:41 PM
