Thread: 4 Motion wiring.
  1. Question 4 Motion wiring.
    Jan 2011
    bovey tracey gb
    Hi I want to fit 4 motion to my Sharan I have worked out the wriing for feeds and earths from a wiring diagram for the rear diff mounted Haldex controller.I need help with a couple of other wires.They are control wires, from the ABS ECU.I need to know how to feed the Haldex controller without the correct ABS ECU for a 4 Motion sytem. Any help or ideas I would be very gratefull . Thanks Bill.
  2. Re: 4 Motion wiring.
    46 Post(s)
    Quote Originally Posted by Bill king View Post
    Can I ask why?
  3. Re: 4 Motion wiring.
    Jan 2011
    bovey tracey gb
    Hi Chris. Ive fitted everything and I had the electric control sorted before I fitted it to the vehicle, BUT, when I tested the lock up on the bench it locked no problem but on the vehicle with weight on the wheels I found that after turning prop for approx half a turn the clutch then slipped. my understanding is that the lift pump is running and primes the sysytem, that is OK, then the clutch input side turns at different rate of speed from its out put, this then starts internal lock up of clutch,(this is the partial lock up I exsperianced and thought was total lock up when I bench tested it)then a pressure regulator adjusts operating pressure internally via a small stepper motor controlled via haldex controller that has a signal from ABS controller and wheel speed sensors.This stepper motor is what I need to control. I hope this makes some sense to you. Thanks for asking. Bill.
  1. Halogen to Bi-Xenon wiring adapter wiring diagram - might be useful for someone
    By kerbdog in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-07-2016, 06:14 PM
  2. My v6 4 motion
    By mark garfoot in forum Show 'n' Shine - Post your efforts here
    Last Post: 31-01-2015, 12:01 PM
  3. Tv in motion
    By jeffshep in forum VCDS - Help Requests
    Last Post: 11-02-2011, 04:17 PM
  4. Question V6 4 motion
    By Tank 95 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-10-2010, 11:27 PM
  5. 4 Motion
    By brycem in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-11-2008, 10:34 PM
