Thread: 1.4 TSI engine faults p0016/p2293 is this the Cam chain?
  1. 1.4 TSI engine faults p0016/p2293 is this the Cam chain?
    May 2010
    Ipswich, UK
    Hi all
    I'm posting here as I understand the Golf Mk5 uses the 1.4 TSI Turbo/supercharged engine (ours is in a 58 plate Touran) and i welcome views from the Golf fraternity! We're seeing two faults P0016 (Crankshaft/Camshaft Correlation?) and P2293 (Mechanical Malfunction - Intermittent?). Car is a 1.4 turbo/supercharged engine CAWC? 140HP. The car does run , and it did have the 'noisy on start-up' sound. It now has a rattly noise that could be top end and/or 'cam chain rattle' (I haven't taken a good look yet)
    Reading on this and other forum I feel this may be the same issue as
    VW Mk5 Golf TSi Engine & Timing Chain Problem - Adam Lewin
    Please can I ask
    - thoughts: is this likely to be the issue??
    - please can you point me to a site advising how to change the chain and tensioners if needed, also info on torque values for the bolts etc
    - which special tools are needed (I've seen this below but not sure if this is the right one ?) I expect additional or alternate specific special tools may be needed)
    VW TOOLS T10170 T10171 T40011 T10340 FSi CHAIN ENGINE TIMING TOOL KIT | eBay
    Very greatful for any help, advice and pointers you can share
    I remain dissappointed that this has happened on a 70k one lady owner from new carefully driven 'quality' marque such as a VW!!
    N
  2. Re: 1.4 TSI engine faults p0016/p2293 is this the Cam chain???
    Kinross Scotland
    Dont start that engine again till you find out for sure. These engins have a history of the chain stretching , jumping some teeth and the engine then mashes itself up.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  3. Re: 1.4 TSI engine faults p0016/p2293 is this the Cam chain???
    May 2007
    knee deep in clunge
    14 Post(s)
    The tensioner fails not the chain stretching replace the bearing carrier chain and tensioner prior to this use a video camera to check for valve contact and if ok fit ad suggested takes around 4 hours
  1. Question Touran Faults p0016/p2293 - Cam chain? (Same as Golf?)
    By fredthedog in forum Touran - Sharan - Caravelle
    Last Post: 04-09-2014, 09:03 PM
  2. Please Help Golf 1.4 170PS Stretched Cam Chain - new engine needed?
    By neosenate in forum Golf MK5 - 2004 - 2009
    Last Post: 08-01-2013, 01:04 PM
  3. 3.0 Tdi Cam belt or cam chain
    By l14m in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-05-2012, 07:42 AM
  4. Timing chain on 1.4 TSI engine
    By brunel in forum Golf MK6 - 2009 - 2013
    Last Post: 15-10-2010, 05:46 PM
  5. Audi 80. Cam belt or Cam chain?
    By Coastie in forum 80 - 90
    Last Post: 03-01-2008, 09:29 PM
