Thread: Thoughts on detailing tape to mask the milky chrome trim
Results 1 to 10 of 14
  1. Thoughts on detailing tape to mask the milky chrome trim
    Jun 2006
    Like many others, my A6 suffers from milky and discoloured chrome trim, the worst of which is on the top of the doors at the base of the window glass, and the strip across the boot lid.
    The cost to replace, and fact it will just return has stopped thoughts of replacement, although I was considering chrome wrap.
    My car is canyon red so I don't think another colour would look right.
    Anyway, seen this and was wondering if anyone has experience of tape and what kind of result could be expected:
    Chrome Detailing Foil Tape Car Stripe Coachline 10m Roll x 20mm Wide NEW | eBay
    I'd only try the simpler bits as mentioned above, and I wouldn't expect this to last forever.
    Thinking it maybe worth a shot to see how it turns out !
  2. Re: Thoughts on detailing tape to mask the milky chrome trim
    Nov 2012
    Somerset UK
    I guess it's worth a try if 2cm will give you enough to tuck under both edges, looking at the width it might be close, appreciating that without sufficient behind it will lift too easily.
    At that price worth trying!
  3. Re: Thoughts on detailing tape to mask the milky chrome trim
    Jul 2010
    Essex, UK
    Quote Originally Posted by MarkTM View Post
    It's available in widths up tp 50mm so should be o.k. on the wider parts of the trim.
  4. Re: Thoughts on detailing tape to mask the milky chrome trim
    Jun 2006
    Good spot think 30mm would do.
  5. Re: Thoughts on detailing tape to mask the milky chrome trim
    Jul 2014
    uk
    Interesting. Any idea/instructions on how to remove/detach the chrome strips?
  6. Re: Thoughts on detailing tape to mask the milky chrome trim
    Nov 2012
    Somerset UK
    Haj, I think OP would do them in situ, others have on here.
    Would be interesting to see how they hold up to the elements & washing
  7. Re: Thoughts on detailing tape to mask the milky chrome trim
    Jul 2014
    uk
    Would also be interesting to see if kids would stay away from it without peeling it off for fun
  8. Re: Thoughts on detailing tape to mask the milky chrome trim
    Dec 2010
    CD UK
    6 Post(s)
    It got me thinking that if Audi had used silver plate you'd get the choice of either polishing them to retain the shiny look, or letting them tarnish to get a dark look. I'll be quite happy when the brightness goes on mine. If I had bought the previous MY car I could have avoided chrome, but not the higher emissions.
  9. Re: Thoughts on detailing tape to mask the milky chrome trim
    Nov 2012
    Somerset UK
    Quote Originally Posted by apole View Post
    Although, having a look at mine today the rear quarterlites on my saloon may prove tricky for two reasons:
    1) It gets quite wide and to get around it will invariably require cutting and a join to get around the curve
    2) Unlike the doors where there is a visible and workable gap, there is no such gap there as it seems to be moulded to the glass surround
  10. Re: Thoughts on detailing tape to mask the milky chrome trim
    Jun 2006
    I wouldn't look to remove the trims, just go over and neatly tuck in all round. Seen a few vids on utube, looks do-able but it may end in tears!
    I wasn't going to attempt the larger bits like quarter lights, far more involved and beyond my abilities. Luckily these aren't too bad on mine.
    Don't think kids likely to peel it off, shouldn't (he says !!) stand out that there is tape there.
    Just an idea at this stage but could improve things for a reasonable cost and if it only lasts a year or two ....
    I would prefer real metal, far easier to look after and more durable. This fake plastic stuff doesn't stand the test of time and seen other cars (like 4 month old Pug 508SW) with same issue.
  1. Question Chrome window trims ...milky damage ?
    By onionman100 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-09-2011, 05:42 PM
  2. Passat CC Chrome/Aluminium Switches... Your Thoughts
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2011, 08:29 AM
  3. New chrome trim surround for dashboard birch wood trim
    By potz1024 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-08-2010, 10:34 AM
  4. Question Chrome trim...
    By trevor666 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2010, 10:51 PM
  5. Chrome Trim
    By wh431 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-04-2009, 08:48 PM
