Thread: The "check engine" light came on today....
  1. The "check engine" light came on today....
    Feb 2014
    Shannon, Ireland
    The coil symbol flashed, indicating an ECU fault (it's a 2L TDI), but didn't light up again after I stopped and started again. The check engine light stayed lit obviously. I have a OBD2 CANBUS cable knocking around somewhere (from my old Volvo S80), but don't know anyone with a VCDS cable. Will the CANBUS cable let me read the codes and reset the light or do I really need a VCDS one?
  2. Re: The "check engine" light came on today....
    Feb 2013
    Gloucester
    57 Post(s)
    You need VCDS mate. Search on here for VCDS users map and see if anyone is local to you.
  3. Re: The "check engine" light came on today....
    Feb 2014
    Shannon, Ireland
    A guy at work had a VCDS cable so I scanned the codes earlier.
    1 Fault Found:
    012547 - Motor for Intake Manifold Flap (V157)
    P3103 - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 35
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.62 V
    Bin. Bits: 00001010
    Torque: 0.0 Nm
    Torque: 300.1 Nm
    So it looks like I have a knackered throttle body, but it could be a lot worse. It'll be next week before I can get the part and do the swap (with help from How to replace intake manifold flap motor, aka "Throttle body valve" on 2.0 tdi engine (Audi A6) - YouTube) but I need a car for the weekend. Is it safe to drive in the meantime?
  4. Re: The "check engine" light came on today....
    Mar 2008
    11 Post(s)
    This might help too:
    VW AUDI Forum - VWAF
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  1. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  2. Oil Pressure Warning Light, Buzzer and Airbag light "On" with ignition "Off"
    By silver4444uk in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2013, 12:19 AM
  3. Replies: 1
    Last Post: 08-02-2010, 12:34 AM
  4. erratic temp guage and "check coolant" light problem
    By Hurley1611 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2009, 10:15 PM
  5. "Check oil level" and yellow oil light
    By sergiup in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-10-2008, 12:06 AM
