Thread: help please Audi A4 2005 newer shape heating help (new engine)
Results 1 to 10 of 13
  1. help please Audi A4 2005 newer shape heating help (new engine)
    May 2014
    northern ireland
    Hi All, i have a 1.9 tdi and the heating stopped working, soon after that the head gasket went. i got the head reskimmed and it would not hold the pressure so i dropped a new engine in it. i thought that the heating not working was a sign that the gasket was going to blow so when i got the new engine i thought that the problem would be solved.
    can anyone help with this problem.
    if i turn the cold air on and change to heat the heat will not come on but if i set the heat to say 25degrees and turn of and back on then i get warm air but not hot.
    please tell me this aint a big job as i have run out of funds now
  2. Re: help please Audi A4 2005 newer shape heating help (new engine)
    andyam Guest
    You need the b7 forum bud
  3. Re: help please Audi A4 2005 newer shape heating help (new engine)
    May 2014
    northern ireland
    Quote Originally Posted by andyam View Post
    dont know how to use this site mate can you paste a link
  4. Re: help please Audi A4 2005 newer shape heating help (new engine)
    Oct 2005
    Have you had a fault code scan?
  5. Re: help please Audi A4 2005 newer shape heating help (new engine)
    May 2014
    northern ireland
    i have a basic scanner , il have to bring it to a garage and get it scanned properly. would it show a fault for the heating
  6. Re: help please Audi A4 2005 newer shape heating help (new engine)
    Oct 2005
    If there are faults present it will show you what they are, yes.
    Who did the engine swap? Was the system bled?
  7. Re: help please Audi A4 2005 newer shape heating help (new engine)
    Southern County Softy
    20 Post(s)
    You could have a temperature flap motor jammed. This is a common fault. It will show on a scan.
    A4 2.5 tdi QS (mapped)
  8. Re: help please Audi A4 2005 newer shape heating help (new engine)
    May 2014
    northern ireland
    got car put on computer, it showed 3 faults to do with the heater flaps, i cant remember what they were the garage said freeze flap or something.
    anyway it seems to be working now so i hope thats it.
  1. Passat B5 2005 last of old shape - Installing rear parking sensors
    By Faces in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2014, 11:01 AM
  2. From 2005 2.7tdi to something newer and bigger
    By furfurfur in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-11-2012, 06:08 PM
  3. 2005 New Shape A4 Headlight Conversion
    By autohausbangor in forum Body Work, Body Styling and Body Kits
    Last Post: 02-10-2010, 07:13 PM
  4. AUDI A6 - Engine fan & heating problem
    By G_MAN_1973 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-02-2009, 04:27 PM
  5. Sat Nav Passat 2005 (old shape)
    By pbriggs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2007, 05:37 PM
