Thread: 302mm disc to 330mm disc upgrade?
Results 11 to 20 of 25
  1. Re: 302mm disc to 330mm disc upgrade?
    Dec 2010
    Wiltshire
    I can't see a problem with ESP/ ABS as braking is done by calculating the speed of individual wheel.
    Never had a problem on a previous cars.
    2 1 0
  2. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    Bexleyheath, England
    Hi bops6. Finding a set will def not be easy, and like you said "rocking horse poo". Considering I am already running the smallest disc available on the 3.0 (321mm) anything bigger will be an upgrade, especially if I can get a set of 4 or 6 pot calipers from a n other Audi. Just bought a set of SS hoses so a step in the right direction.
    Researching part numbers for matching calipers & carriers, any help will be appreciated.
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
  3. Re: 302mm disc to 330mm disc upgrade?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by crazy4alfa View Post
    I agree , I have thought this , but previous gen of ABS do require coding Link:- Audi A4 (8D) Brake Electronics (Bosch 5.3 ABS/EDS/ASR/ESP) - Ross-Tech Wiki
    Above link is a redirection from the A6 4B/C5 wiki.
    And they would have been using same principles as Bosch 8.0 that we have? Just no info on Bosch 8.0 coding, so are we going to say it does not matter?
  4. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    Gup, when I did the upgrade on my C5 no coding was needed. But an interesting read especially re steering angle.
    George
  5. Re: 302mm disc to 330mm disc upgrade?
    Dec 2010
    Wiltshire
    I haven't seen brake coding on C6 whilst using VCDS.
    You'd want to recode brakes if you're using high performance pads.
  6. Re: 302mm disc to 330mm disc upgrade?
    Dec 2010
    Wiltshire
    Joedredd you mean you never did any coding.
    312mm front brakes were used on V5/V6 engined due to extra weight. In order to restore balance 255 disc should have been used on the rear.
  7. Re: 302mm disc to 330mm disc upgrade?
    #17
    Sep 2011
    Quote Originally Posted by joedredd View Post
    That is a redirection page from when you click ABS/brakes in the A6 4B / C5 wiki, perhaps you never knew it needed coding? perhaps it make no discernible differences?
    Anyway as only info when replacing ABS unit (Bosch 8.0) is to use the code in the old unit for new on the web god know how it is built up ...
  8. Re: 302mm disc to 330mm disc upgrade?
    #18
    Jun 2009
    Not on my C5, no. Just swapped calipers & carriers, fitted new discs/ pads.
    George
  9. Re: 302mm disc to 330mm disc upgrade?
    #19
    Jun 2009
    Ok spent the last few minutes checking part nos. Now unfortunately I cannot find my code on sticker (faded) so will contact Audi tomorrow to confirm.
    Code PR1LT 314mm x 25mm disc, caliper 4B0615123, carrier 4B0615125C
    PR1LG/ LD 321mm x 30mm, 4B0615123, 4F0615125
    PR1ZL/ LH 347mm x 30mm, 8E0615123, 1K0615125B
    S6/ PR1LJ 385mm x 36mm, 4E0615123C, 4F0615125B
    At least I can find the right parts now.
    George
    May 2012
    essex
    On my b5 i went to a 360mm disc with 6 pots and no coding with no issues, can't really see why it would be needed
    2007 3.0tdi le mans
    hybrid turbo, decat,miltek, 20's etc
    330-350 bhp
    450-500lbst
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  1. Audi A4/A5 MMI Upgrade Disc Set (8K0 998 961)
    By vwrich85 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 22-01-2019, 03:24 AM
  2. 2010 MMI 3G Sat Nav upgrade Disc
    By AudiW in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 11:24 PM
  3. Please Help 312mm disc upgrade - what pads?
    By bambamjj in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-01-2011, 09:19 PM
  4. Question How to upgrade single cd to a 6 disc changer in '04 A6?
    By pimpin gimp in forum In Car Entertainment
    Last Post: 10-02-2010, 12:45 AM
  5. Audi DVD Sat Nav Disc Upgrade... CONFUSED...
    By Birchy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-02-2009, 05:32 PM
