Thread: 302mm disc to 330mm disc upgrade?
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. 302mm disc to 330mm disc upgrade?
    Jun 2009
    Bexleyheath, England
    Hi all
    Just wondering if the above upgrade is possible?
    I did something similar on my C5, so is this a straight swap with carriers and discs or is it too complex?
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
  2. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    90 views and no replies
    Someone must now if this is doable.
    George
  3. Re: 302mm disc to 330mm disc upgrade?
    Aug 2011
    Meath
    It depends on what calipers are on the car. Add a photograph
  4. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    Thanks for the reply. But if I am looking at changing calipers & carriers does it matter at what I am running now?
    *** Oops my bad, didn't mention that in OP
    George
  5. Re: 302mm disc to 330mm disc upgrade?
    Aug 2011
    Meath
    Some hubs don't have removable carriers
  6. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    Quote Originally Posted by Doctle Odd View Post
    How can I check if mine are removable? any particular part no.s?
    George
  7. Re: 302mm disc to 330mm disc upgrade?
    Sep 2011
    Lurking over a keyboard ...
    All variants of carrier on our model are removable.
    A quick search in EPC reveals our 3.0 TDi has same Link:- item 13 as the 8/10 cyl, perhaps even 385mm is doable?
    This discussion of brake upgrades has happened a few times and each time my mind says what about coding ABS to have knowledge of brakes upgrade?
    Did once have a google but not seen anything and keep forgetting to check via VCDS if there is a helper balloon/info in there.
    2 1 0
  8. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    Quote Originally Posted by gupsterg View Post
    That's what I thought, but I started questioning myself.
    I do think you are right, considering fitting S/RS 6 set up
    From my research and discussions none is needed, as even the master cylinder is same size (but prepared to be proved wrong).
    As soon as I find some calipers I will give it a go. I fitted 312mm set up on C5 and was so much better, and think the same will be happen on C6.
    Worth giving it a shot, let us know if you find anything.
    George
  9. Re: 302mm disc to 330mm disc upgrade?
    Jun 2009
    Ok little bit more research. The RS models have a fixed carrier (not a replacement part), but the S6 is a removable carrier. So looking for a S6 set up then.
    George
  10. Re: 302mm disc to 330mm disc upgrade?
    May 2012
    essex
    Quote Originally Posted by joedredd View Post
    I spent a long time looking for a used set of s6 brakes and have up in the end, they're like the rocking horse doo doo lol.
    I'm still looking into fitting 18z calipers to my extexisting 347mm discs with custom carriers that way disc and pad replacement is still cost effective
    2007 3.0tdi le mans
    hybrid turbo, decat,miltek, 20's etc
    330-350 bhp
    450-500lbst
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
    2 1 0
  1. Audi A4/A5 MMI Upgrade Disc Set (8K0 998 961)
    By vwrich85 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 22-01-2019, 03:24 AM
  2. 2010 MMI 3G Sat Nav upgrade Disc
    By AudiW in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-09-2013, 11:24 PM
  3. Please Help 312mm disc upgrade - what pads?
    By bambamjj in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-01-2011, 09:19 PM
  4. Question How to upgrade single cd to a 6 disc changer in '04 A6?
    By pimpin gimp in forum In Car Entertainment
    Last Post: 10-02-2010, 12:45 AM
  5. Audi DVD Sat Nav Disc Upgrade... CONFUSED...
    By Birchy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-02-2009, 05:32 PM
