Thread: Hearing not working properly and white smoke
Results 1 to 9 of 9
  1. Hearing not working properly and white smoke
    Dec 2012
    Ipswich
    Hi all for the last four weeks my heaters haven't been getting hot and it makes a kind of fluffing sound every now and again from behind the dash so I was going to flush the matrix out this weekend however I started the car up bit lumpy but cleared and it was find drove it down the carriage way 70 mpg fine power normal pick my mrs up from work same journey 20mind of 30 mph driving all fine parked up then when I started it about 4 hours later on the first start it stalled kinda strange never done that before so started again lumpy and wanted to stall so I pumped the pedal to keep it going loads of white smoke it's a bre engine 2.0 tdi 140 bhp
    Any ideas ????
  2. Re: Hearing not working properly and white smoke
    Dec 2006
    Stoke/Congleton
    Could be the egr cooler leaking water into the air intake and causing steam out of the exhaust, but if it smells of diesel it could be an injector problem. The water leak is most likely and can cause the car to lock up on start up,you should see water in the intake pipe if its that.
  3. Re: Hearing not working properly and white smoke
    Dec 2012
    Ipswich
    Would the leaking egr make it stall and run lumpy plus no heat I thought head gasket but it seems like it could be anything on these dam engines
  4. Re: Hearing not working properly and white smoke
    Dec 2006
    Stoke/Congleton
    It can make it run lumpy,I think its on the same circuit as the heater.
  5. Hearing not working properly and white smoke
    Dec 2012
    Ipswich
    Changed the egr valve cooler now no smoke runs fine heating is getting better too
  6. Re: Hearing not working properly and white smoke
    Aug 2013
    Surrey
    Im having same issues. Where did you get EGR COOLER from?, how much did you pay for it? did you fit yourself? my heater has been running cold and I had smoke coming out exhausts. I bypassed the EGR COOLER an now no smoke from exhaust.
    soory for all the questions, just keen to sort this issue out �� Soooooo frustrating ay!
    Loving my Audi
  7. Re: Hearing not working properly and white smoke
    Dec 2012
    Ipswich
    Hi the egr cooler was around 350£ but I got a guy to fit it 500 all in get it done soon or you can hydroloc it
  8. Re: Hearing not working properly and white smoke
    Aug 2013
    Surrey
    I've found a EGR COOLER brand new for £270.00 an was gonna fit myself. I'm not driving it at mo,,,,, what do you mean by hydroloc?
    Loving my Audi
  9. Re: Hearing not working properly and white smoke
    Sep 2008
    chester
    17 Post(s)
    He means Hydraulic,water in a cylinder is bad news,you can't compress water so its got to go somewhere.
  1. Central locking not working properly, help
    By Lee8 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-10-2012, 09:29 AM
  2. Question Heater isn't working properly
    By hardpack in forum Golf MK4 - 1999 - 2004
    Last Post: 04-10-2010, 06:43 AM
  3. A3 indicators not working properly
    By flynnejammin in forum Audi A3 - Archive Topics
    Last Post: 25-01-2008, 08:49 PM
  4. Wipers not working properly
    By Kunal in forum Archive posts
    Last Post: 31-10-2007, 04:29 PM
  5. aircon not working properly
    By bg_doyle in forum Audi A4 - Archive Topics
    Last Post: 13-04-2007, 11:26 AM
