Thread: whats up with my radio. golf mk4
  1. whats up with my radio. golf mk4
    Sep 2007
    i have a standard gamma radio and every time i turn the car on i have to turn the radio on seperate, is this normal. then it either comes up learn or safe. if it comes up learn i just push number 1 and it brings up my saved radio station, does the radio need setting to stop this, i dont have the radio manual to check. when it comes up safe i dont touch it until it beeps but sometimes it asks for the code which i dont have. does this happen to anyone else and how do i sort it.
    and do you know how i can get the code.
    thanks
    also my radio dont hold its memory, for instance if i was listen to a cd say track 12 then turn the car off, when i start the car and select cd it will be on cd1 track 1 any ideas
  2. Re: whats up with my radio. golf mk4
    Aug 2007
    Northern Ireland
    Mine says "safe" when the buttons (radio preset buttons) are removed and the radio is turned on.. Maybe its a bad connection between the buttons and the radio.
    Pete
  3. Re: whats up with my radio. golf mk4
    Coventry
    Quote Originally Posted by mobitune View Post
    Pete
    .............and when you push 1 the connection is made good.
  4. Re: whats up with my radio. golf mk4
    Sep 2007
    Im not sure if it is a loose connection. if it was the radio would not come on would it and surely would always say "safe"
    thanks for your replys
    anyone have any other ideas.
  5. Re: whats up with my radio. golf mk4
    Aug 2007
    Northern Ireland
    When you turn the radio on without the buttons it says "Safe"
    When your radio says "Safe" it doesn't see the buttons. When you press 1 you are making the connection hence the radio starts working.
  6. Re: whats up with my radio. golf mk4
    Dec 2006
    Wiltshire
    It sounds as if you have lost the permanent 12v feed to the radio. If you are on the original wiring check your fuse box for a blown fuse.
    If the wiring is not original you should have a switched 12v feed and a permanent 12v to the radio with the ignition on. If you haven't that's your problem.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  7. Re: whats up with my radio. golf mk4
    Aug 2007
    Northern Ireland
    Pete
    Just to correct this, I was mistaken.. when the buttons are removed it says "safe" behind them... but on the display it says "front missing" or something like that.
  1. Golf Mk4 radio can be fitted on MK3?
    By inbritain in forum Golf MK4 - 1999 - 2004
    Last Post: 14-08-2007, 04:26 PM
  2. vw gamma radio to mk2 golf
    By need4vti in forum Golf MK2 - 1984 - 1992
    Last Post: 07-08-2007, 10:49 PM
  3. Delta radio in Golf Mk4
    By tr85858 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-06-2007, 09:44 PM
  4. Golf radio
    By Ben in forum Chat - Anything with wheels
    Last Post: 07-05-2007, 09:59 PM
  5. Golf Mk V Radio
    By barryterrell in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-01-2007, 12:14 AM
