Thread: 120k service info?
  1. 120k service info?
    Feb 2007
    Leicester
    I have a 2001 A4 115PD Tdi. It is coming up to the 120k mark and i want to give it a full service. I am not sure what should be included in this major service. Am i right in thinking it would include:-
    Oil - PD type
    Oil filter
    Air filter
    Pollen filter
    Timing belt + tensioner
    Also, check brake pads.
    I would ideally like to change anything else that is not too expensive but could give me problems so i also thought:-
    Transmission oil change?
    Other drive belts?
    Can anyone advise me of what should be included for another trouble free 60k?
    Thanks a lot
    Wid77
  2. Re: 120k service info?
    135 Post(s)
    2036 Post(s)
    There is quite a lot more to it than that but the cam belt should be done every four years or 60k after the initial change (on a 115 PD) at 40k. Brake fluid is every two years. What needs doing really depends on what has already been done.
  3. Re: 120k service info?
    Feb 2007
    Leicester
    Thanks for the reply. The car has a full Audi service history up to 96k when it had an oil change an an inspection service. I had an oil and filter change at an independent specialist at 106k when i bought the car. I will have the next service done at about 118k. I know the cambelt will need to be done as the last time it was changed was 59k (10.9.03).
    Cheers.
  1. MAF Info pls
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 22-06-2012, 03:50 PM
  2. A6 tdi TURBO info
    By A6dub in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-10-2007, 11:28 PM
  3. Mpg Info For A4 1.9 Tdi (130)
    By minz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-09-2007, 03:30 PM
  4. tdi golf's mk3 and mk4 info
    By johnathan in forum Golf MK4 - 1999 - 2004
    Last Post: 10-09-2007, 11:34 AM
  5. info help
    By noel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-08-2007, 05:10 PM
