Thread: A4 1.8T wont start!!!
Results 1 to 8 of 8
Hybrid View
  1. Angry A4 1.8T wont start!!!
    Sep 2007
    swindon
    Was driving my car at low revs close to my home last week and my car cut out, my initial reaction was that it had popped out of gear. the engine actually cut out and would not restart. After getting the car home i have discovered that i am getting fuel to the engine, it is also sparking and the ecu is fine. I am starting to get baffled as i have checked the timing belt which has been done in the past 6 months and it is tight, is it possible that it would slip???? the only other thing i can think of is the exhaust has got blocked but why would it cut out with no pryer warning?????? have not noticed a lack in performance or heard any dodgy noises. Can anyone help?????
  2. Re: A4 1.8T wont start!!!
    134 Post(s)
    2013 Post(s)
    A fault code read before you waste any more time chasing around in circles.
  3. Re: A4 1.8T wont start!!!
    Sep 2007
    swindon
    Have already diagnosed, only one fault code - turbo pressure limiting solenoid - apparently is only an intemittent problem, would this create a build up of crap in my exhaust and choke it up? have also checked the crank sensor which is good.
  4. Re: A4 1.8T wont start!!!
    134 Post(s)
    2013 Post(s)
    So you have fuel, spark and no appropriate codes and I would be surprised to say the least if the exhaust blocked to that extent instantly. I have seen a cat fail like that once in twenty five years and it would still idle even then. I think you now need to actually check the valve timing itself and then, if that is OK, check the fuel pressure. You may have fuel delivery, but the pressure may be too low.
  5. Re: A4 1.8T wont start!!!
    Sep 2007
    swindon
    Thanks crasher, have now dicovered that one of the valves is inbedded in one of the pistons. Mega ouch, still dont know why it has happened though. now i have the decision do i rebuild,replace or start a fresh.
  6. Re: A4 1.8T wont start!!!
    134 Post(s)
    2013 Post(s)
    The 20v has a nasty habit of doping that. I have just fitted a new unit in my Octavia 20vT and I fitted a full VAG exchange unit. Two year warranty. I am a VAG specialist and I have built hundreds of engines but the price for the unit was unbeatable, I couldn’t have built it myself for less. The head will probably be a write off as well.
  1. A6 1.9 TDI Wont Start When Warm
    By mrcheeezy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-07-2007, 07:32 PM
  2. sharan just wont start
    By alistair in forum Touran - Sharan - Caravelle
    Last Post: 06-05-2007, 02:08 PM
  3. Polo wont start
    By nige61 in forum Polo - Derby - Lupo - Fox
    Last Post: 12-04-2007, 10:23 PM
  4. a6 1.8t wont start
    By loco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-01-2007, 10:22 PM
  5. a6 1.8T wont start
    Last Post: 06-01-2007, 12:21 AM
