Thread: Intermittent fault injector 3
  1. Intermittent fault injector 3
    Mar 2010
    Weston-super-Mare
    Hi Guys,
    Just had the car back from its MOT which it thankfully passed, however while it was in I asked the garage to check if anymore fault codes had come up after my issues when I bought the car.
    Now my wife had told me that twice she has had the engine fault garage warning but I put this down to the well documented steering column and immobiliser issue as previously a good number of logs were made for this so thought nothing more of it as I planned to do the DIY fix if it became an issue
    To my surprise the Garage told me today that there has been two intermittent inject faults logged on injector 3.
    I spoke to VW when I bought the car and was informed that all of the injectors had been replaced under warranty.
    So I was interested to hear your thoughts and what would be my best course of action.
    David
  2. Re: Intermittent fault injector 3
    SE London
    You need to know when these injector 3 faults occured. And whether they co-incide with the times your wife told you the "engine fault garage warning" CEL had occured. The VAS fault analysis the dealer did would've given the dates and times. If they've not been cleared then they may still be in the engine module's memory and can be retrieved with an Autoscan from a program called VCDS which emulates dealer's VAS
    See if you can get one done? Here's a locator of enthusiasts with VCDS who often will do an Autoscan for beer tokens:
    VWAF User Location Map - VCDS - Google Maps
    If you get a scan, post here?
  1. Possible Injector Fault
    By jim_tdi in forum Golf MK5 - 2004 - 2009
    Last Post: 06-05-2014, 08:36 AM
  2. Please Help Touran 2.0 TDI faulty injector wiring loom and now possible injector fault
    By bigdaddysi in forum Touran - Sharan - Caravelle
    Last Post: 28-10-2013, 07:13 PM
  3. Injector Fault 130 Highline
    By gernarrdo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2011, 07:16 PM
  4. Diesel injector fault
    By Ianboom in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-12-2010, 02:35 PM
  5. tdi 130 fault injector 3
    By deka in forum Golf MK4 - 1999 - 2004
    Last Post: 02-03-2009, 07:56 PM
