Thread: knocking noise help
  1. knocking noise help
    Oct 2013
    belfast
    ive a knocking noise coming from the of my A4 B6 1.9 tdi 2002. i just replaced the shocks and springs with coilovers. now the car is on 19" rims and sitting nicely even with a full car. so its not sitting on the tiles. but anyway the noise was there before i replaced the springs and shocks. so if anyone can help out with eliminating as to what i can check. and also maybe thinking about replacing ie bushes and that many thanx
  2. Re: knocking noise help
    7 Post(s)
    Most likely the C links that attach the anti roll ball to the front front lower arm.
    But could be any of the front arm bushes or balljoints.
    I take it you released the inboard mounting bush bolts, including the rear beam bush center bolts when you lowered it and re-torqued at the new / lower arm angles? If not they will wear out a lot quicker, in fact if they have not ever been replaced they are due on a car that old. Lowering without making those adjustments will soon finish them off.
  3. Re: knocking noise help
    Oct 2013
    belfast
    cheers for the reply. should of mentioned i didnt actually fit them myself had a fella fit them for me. if i was looking at the C links what do i look out for or and were abouts are they thanx
  4. Re: knocking noise help
    Sep 2008
    6 Post(s)
    Quote Originally Posted by markoA4 View Post
    The C links connect the lower front control arm to the anti-roll bar. The C links are easy to identify, as they're shaped like the letter suggests. Normally the rubber bush wears and it develops too much play. While you're there I'd replace the front ARB bushes which hold the anti-roll bar. Both parts are relatively inexpensive. Use Lemforder or Meyle which is OE and genuine Audi rubber ARB bushes.
    More details here. This is for B5 model, but B6 is exactly the same. http://www.audizine.com/forum/showth...abilizer-Links
    2016 BMW i3 REx (80k)
  1. Please Help Knocking noise
    By Mickeymoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-12-2013, 07:40 AM
  2. Knocking noise
    By Gazza-a4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2013, 06:33 PM
  3. Knocking noise
    By mikea31.820vt in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-02-2011, 08:20 PM
  4. knocking noise
    By biggs001 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2010, 07:58 PM
  5. Question Knocking noise
    By nick.king in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2008, 09:20 PM
