Thread: Power folding wing mirrors
Results 1 to 8 of 8
  1. Post Power folding wing mirrors
    Sep 2008
    SE London
    I finished the upgrade to Power Folding Door Mirrors yesterday. In addition to the standard features of electric adjust, and heaters I get downlight, auto dim on drivers' side, and of course the power folding.
    It's not auto-power folding i.e. keys in IGN on and they fold out. Or the reverse for keys out/lock. Auto power folding is available on the CC I believe, with 3c8 series control modules. Folding mirrors can't be added into the convenience menu in your MFA on the B6.
    If you've got the patience (and the OCD!) to search through scrapyards and for sale forums, eventually you'll find them. I got the two mirror units complete with switch for £150. I swapped my old modules/window winder motors for the uprated power folding capable ones which also came from a B6 '06MY:
    Install isn't too bad. Getting the door cards off is a pain though. Remove side armrests and unplug. Start by removing the two bottom bolts that go up recessed through doorcard. Using a large plastic lever starting at the opening side, lever between metal of door inner and doorcard and unclip as you go around door card leaving the top two until last so as you can lift the card vertically. You can then reach in to free the door release lever hook from door opener lever, and loom plugs.
    You will break some of the brackets. And some of the plastic plugs too. They're 48p each from VW p/n 6Q0 868 243. Any fractured brackets can be repaired by plastic weld or superglue leaving 48 hours to set. Some of the plugs will be stuck in their brackets. They can be removed with a wire coat hanger wrapped around then a sharp tug to release. Who designed this?
    You can change the shell/cap of the mirrors you find with your old ones in correct colour. Or get either another shell in primer, or your own colour, from VW spares. Or just mask and spray.
    To remove mirror there's three holding bolts under the treble speaker cover that has to be removed first. Then a spigot that disengages from a plastic housing. With the long lead disconnected, it will thread through the cable gland.
    Power Folding Mirrors - Info Sheet
    Relevent hardware needs to be installed. Audi's have a "per key" setting. If one key is used to
    setup, then the other won't work the power Folding mirrors until that too is setup.
    The "puddle light" (downlight) in the mirrors' stalk only operates when light sensor is active.
    For the Passat CC power folding mirrors are installed for free if memory seats are specified when car is ordered new.
    as a factory-fitted option. (Can this be confirmed for UK buyers or is this a US-only sales package?)
    The 1k0 controller part numbers are Golf prefixes. Quite a few Golf parts are used in the Passat
    B6. 5k0 is a Golf MkVI prefix. Not all Golf MkV controller suffixes are four door, some are two
    door only. ETKA has a listing. Common Golf VCDS codings are: drivers' - 4790, pax - 5046. Another
    poster with "AL" and "N" controllers uses drivers' - 694, and pax - 950
    Not all door controllers will accept power Folding mirrors. But those different controllers arn't identifiably
    listed in ETKA between power Folding and just electric adjust/heating only. These are the available suffix
    letters, market, and cars that will support power Folding mirrors:
    K Gen 2 Min Golf, Jetta (tested on my Passat B6, did not perform power fold)
    L Gen 2 Max ROW Jetta, Golf Jetta 5/05-6/06, Golf 6/05-5/06
    L Gen 2 Max NAR Jetta, Golf (all) 10/05->
    L Gen 2 Max ROW, NAR Passat 3/05-5/06 (used on my B6's upgrade power fold works)
    There are some wiring differences between these two generations. See the MyGTI link below for
    details: a four wires' move on the controller for the central locking. And a three wires' move for the
    window button
    M Gen 3 Min
    N Gen 3 Max ROW Golf 5/06-> (2007 in VIN)(Z77 or Z72 options are 6XG)
    Q Gen 3 Max ROW Jetta, Golf Variant, NAR Jetta Wagon 7/06-> (2007 in VIN)
    Q Gen 3 Max ROW, NAR Passat 5/06-> (2007 in VIN)
    AG " (unknown)(Z0X, Z0Y, Z1R versions OK) (VW price for info: £167 each +VAT)
    AL " "
    The features supported (subject to revision letter) by these controllers are:
    Rear Lid Remote Unlock Button (E233)
    Ambient Mirror Illumination (downlight)
    Mirror Turn Signals (repeater)
    Interior Door Handle Illumination Installed
    Automatic Run Active
    Mirror Heater Installed (set by timer, not a thermistor)
    Door Exit Warning Light Installed (the red lights at door bottom)
    5-Door Chassis (four doors & tailgate)
    Seat Memory Installed
    Right Hand Drive
    Safe-Motor not installed
    Pinch Protection inactive
    Folding Mirrors installed ('08MY+ with Gen 3 controller)
    Manually Operated Convertible Top installed (not Gen 2)
    Start/Stop Function installed ('10MY+ with Gen 3 controller)
    These are the option codes for wing mirrors as shown in Golf coding stickers:
    6XC = Exterior mirrors: electrically adjustable
    6XN = Exterior mirrors: electrically adjustable, separately heated
    6XG = Exterior mirrors: with memory function, electrically adjustable/heated
    6XT = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable, separately heated
    6XQ = Exterior mirrors: with memory function, electrically foldable/adjustable, separately heated
    More information on module cababilities at:
    Volkswagen Golf & Jetta Door Controller Information Mark V | my-gti.com
    Some work in 2007 had been done on early controllers (3B) to convert them to power Folding capable.
    This involves adding a missing IC to the PCB (it's a 6208-3G). And some binary eprom code re-coding.
    More details at: Folding Mirrors with VDS-Pro - Page 2 - TDIClub Forums
    Information on fitting folding mirrors - Tutorials and Guides - R32OC | VW Golf R32, Golf R and other .:R Vehicle Owners Club.
    My ('06MY SEL Estate 3c5) original from factory door controllers as seen in VCDS Autoscan are:
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K<--- suffix letter ^^^^
    Component: Tuer-SG 024 2366 ability & generation
    Coding: 0000757
    Shop #: WSC 05311 000 00000
    VCID: 364DEB2941FBC4AE71B-8063
    No fault code found.
    and
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0000756
    VCID: 3753E62D46F13DA66AD-8062
    An '06MY with power Folding mirrors gives the same part #s but with an "L" suffix letter. Latest
    dealer ETKA (Jul'14) also gives same part # with "L" with a software revision 038 (driver side) and
    042 (pax side) Software version numbers are on the stickey label of the unit, not shown in VCDS.
    No "Foldable mirrors installed" option is listed in VCDS for GEN2 controllers.
    +0004096 is the listed option to add when coding a GEN3 controller.
    Same year but with OEM from factory folding mirrors:
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
    Part No: 1K0 959 701 L<--- suffix letter ^^^^
    Component: Tuer-SG 024 2462 ability & generation
    Coding: 0000695
    Shop #: WSC 00430 210 83132
    and
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
    Part No: 1K0 959 702 L
    Coding: 0000694
    VCID: 3851E5114BEF32DE637-806D
    These codings show original doner car didn't have exit lights fitted to the doors (+000064)
    There is a Folding Mirrors option to enable in VCDS for Gen 3 controllers. This option isn't there
    for Gen 2 controllers, although Gen 2 (MAX2) controllers provide power folding.
    VCDS has measurment block 3 channel 3 (Mirror Folding Switch) to check operation.
    Dealer spares says the window winder/controller on the window motor is not seperately available.
    An '06MY with power Folding mirrors installed has 1k0 959 793 H for drivers side, and 1k0 959 792 H
    for pax side. These are the controllers that arn't available seperately from VW. If you need
    this, AliExpress offers "OEM VW Original Side Rear View Mirror Fold Module For VW Golf MK6 Passat B6
    B7L 5KD 959 793 A" $88.49 at:
    http://www.aliexpress.com/store/product/OEM-VW-Original-Side-Rear-View-Mirror-Fold-Module-For-VW-Gol f-MK6-Passat-B6-B7L/1020613_1624335746.html
    Audi Folding Mirrors Coding Info (not shown on Gen 2 controller)
    Enabling Drivers Door Folding Mirror
    [42 - Door Elect. Driver]
    [Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit -> 4 Change 0 to 1
    Or Check the box for "Foldable Mirrors Installed "
    Enabling Passenger Door Folding Mirror
    [52 - Door Elect. Pass]
    Enabling MMI Menu for Folding Mirrors (not shown on Passat 3c0 module)
    [46 - Central Conv.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 7 Bit -> 7 Change 0 to 1
    Switches
    The original switch that doesn't offer a power folding position but a heating position is 1k0 959 565 F
    If you don't like the knob styles of your new purchased switch, the original black only knob will remove from its spindle with a gentle pull between thumb and forefinger
    The switch that offers both mirror power folding and mirror heating positions with brushed aluminium
    style knob is "VW Golf 5 Jetta Passat B6 Electric Mirror Switch Folding Mirror 1K0 959 565J" £18.99 inc p&p available from:
    VW Golf 5 Jetta Passat B6 Electric Mirror Switch Folding Mirror 1K0 959 565J | eBay
    The switch that offers both mirror power folding and mirror heating positions but with chrome knob for £6.99 inc p&p is at:
    http://www.ebay.co.uk/itm/NEW-Chrome-Panel-Mirror-Switch-knob-Fit-For-VW-Passat-B6-Tiguan-/300858245 064?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+ Make%3AVW|Model%3APassat&hash=item460c8c7fc8
    Coding Generation 2 Drivers' Side Using VCDS
    The only difference between the coding for a non-power folding and a power folding controller is the
    downlight (ambient lighting) value 2. Some cars don't have door exit warning lights installed
    value=64. So that value would have to be added. Values for a non-folding mirror capable drivers'
    module (K Min2) total 757 as they don't have a downlight (+000002). Values for a power Folding
    mirror capable drivers' module (L Max2) total 759:
    Right Hand Drive model 512
    Five door 128
    Exit warning light 64
    Mirror heating 32
    Autorun 16
    Mirror turn signals 4
    Downlight (ambient) 2
    Rear lid remote 1
    = Coding = 0000759
    The Passenger side is coded 0000758 because there is no rear lid remote on that door. (+0000001)
    There is no coding option for a GEN2 controller for drivers' side auto-dimming wing mirror. That's
    wired directly from your auto-dimming rear view mirror when switched on. To test, put finger over
    light sensor hole on rear left side of mirror. In 15 secs or so, you should see the drivers' wing
    mirror change to be noticeably darker with a band of un-dimmed mirror all the way round outer mirror
    edge. You can recognise a auto-dimming rear view mirror by it's slightly yellow band around edge.
    ECS in the US charge $422 +s&h for a heated auto-dimming rear view mirror glass for the B6.
    Pix and ETKA diagrams to follow
  2. Re: Power folding wing mirrors
    Sep 2008
    SE London
    Here's a couple of (LHD) diagrams which I hope will show a bit more detail of above:
    B6'06 Conti Drivers' Side Door Card ETKA diag.jpgB6'06 Conti Drivers' Side ETKA diag.jpg
    Door panel.jpg(4) is door lock pull hook
    And a pic of the (LHD) door card inside. Those wonderful clips are circled in red
    Good video on how to change door mirror glass, caps/shell, and sealed indicator repeater unit at:
    VW Passat 3C mirror cap, glass and indicator repeater replacement - YouTube
    Sealed indicator repeater units are available for £10 ea inc. VAT inc. p&p from (this URL for the left or NS):
    Genuine new Left side Wing Mirror Turn Signal Indicator 1K0.949.101 | eBay
    The downlights are standard W5W bulbs. Changed mine for 2-SMD LEDs. You really need 5-SMD for decent road illumination of where you're going to step.
    Last edited by RichardSEL; 16-08-2014 at 10:54 AM. Reason: door card pix, video, indicator units, LEDs
  3. Re: Power folding wing mirrors
    Sep 2008
    SE London
    Fitted two off each side Red LEDs in parallel with the mirror heater supply. Used Maplins's A40CY lens LEDs 12V 20mA with resistor and trailing leads pre-prepared and shrink wrapped £7.49 inc. for a four-pack:
    http://www.maplin.co.uk/p/prism-car-...d-4-pack-a40cy
    Remove mirror first by adjusting fully inward then very gently fingers under outer edge and slowly lever outward with folded blanket or similar underneath on ground -- just in case. ECS want a kidney for a replacement heated, auto-dimming mirror alone. The backing plate hooks into a plastic holder.
    There are two spade connectors for the 12V heater supply that will be corroded on. If you have auto-dimming there's also a plastic clip-locked plug to de-clip and remove. Spray with Servisol or similar (Maplins's N61AN) before attempting removal to free any dried car wash soap.
    I soldered the leads of two LEDs' in paralell to the heat wires' connectors (Black/red +ve, Black -ve for a change!) then tucked the wires around the back of the plastic holder to allow for the holder to swivel adjust without being hindered. You can only place the LEDs about ½" close to the mirrors' edges without fouling their movement. I used masking tape across the holder initially to gauge position the illumination effect. Lens's should point toward mirror edges -- one at side, one at top of each mirror. And will superglue in position later.
    These 20mA LEDs' brightness are just enough to illuminate the inner edge of the mirrors' dishes in daylight without being distracting. At night they illuminate through the edge of the mirror which glows when the mirrors' heaters are on
    Each mirror's heating element measures about 5 Ohms, so about 2½A each when running. They only get current when the engine's running. You can use larger 50mA LEDs but didn't see any at Maplins with series resistor and leads already prepared. And you run the risk of them being distracting when on.
    There's also a mod for 20mA LED illuminated interior door handles. But didn't fancy taking the door cards off again to fit, what with those convenient clips
  4. Re: Power folding wing mirrors
    Dec 2007
    Hi Richard. I am trying to upgrade a mk6 at the moment to power folding mirrors. I am a bit confused as I have fitted both mirrors with motors and a switch. I have programmed both door controllers but only the passenger one folds. I plugged the drivers one into the passenger control module and it works (out when switched in and in when switched out). I can't understand why the drivers doesn't work as the wiring is obviously there and there are pins in the controller? Do you think I need different controller or what is this about adding an ic to the PCI? Any info appreciated.
  5. Re: Power folding wing mirrors
    Sep 2008
    SE London
    Not a Golf head here but from what I remember (it was last year!) the two platforms Golf MkV and Passat B6 are similar in many but not all respects. I don't know all of the components or coding you'd need for Golf MkVI
    If your pax mirror folds but driver's doesn't do you have independent mirrors' operation switched on or off in your MFD? Most awkwardly I found that it had to be switched off for both folding otherwise only one would fold when the drivers' fold switch was operated. This means that when you try and reset your mirrors' reflective angles both move instead of how you really want: adjustment selected by the switch each independently.
    Have you changed the switch too?
  6. Re: Power folding wing mirrors
    Dec 2007
    Thanks for the reply. I will check the individual settings I am sure at present they are set to synchronised. Yes I did replace the switch. There is also a delay of about 20 seconds after you turn the switch back out before the passenger mirror folds back out (it folds in immediately)?
  7. Re: Power folding wing mirrors
    Dec 2007
    The mirrors were set together but unfortunately changing them to individual makes no difference
  8. Re: Power folding wing mirrors
    Sep 2008
    SE London
    If both the mirrors work on pax side then there's something wrong in the wiring or controller/motor in the drivers' side.
    Do you have auto dimming internal rear view mirror?
    What is your original and then changed coding for the drivers' side controller?
    Post your Autoscan so we can see if there's is fault being reported by controller?
    There may be more informed people in the Golf MkVI forum as here's Passat B6 2005-2010.
    I see that Crasher is helping you out there so don't want to cross what information he's offering... But regarding wiring, on the B6 all the wiring was there because I had the auto-dim rear view mirror. This is needed. If you don't have one of those you may be missing some wires. Again, can't say how the MkVI is wired up.
    I took my control modules/motor units and mirrors from a B6 scrappy AFAICR '08MY. Where did you get your parts from?
    BTW, the part about adding an IC in my help .doc was for B5/B5.5
  1. Folding wing mirrors on lockup
    By Spud312r in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 04-01-2014, 10:52 PM
  2. Question Electric Folding wing mirrors
    By PerryGarrod in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-03-2013, 12:40 PM
  3. Automatic Folding Wing Mirrors
    By steallan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2012, 03:08 PM
  4. Folding wing mirrors
    By h7ptw in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2009, 07:33 PM
  5. Electric folding wing mirrors for A4 B8
    By PerryGarrod in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 09-12-2008, 03:15 PM
