Thread: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
  1. can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    May 2013
    lancashire
    advice needed please i have a 2010 s-line avant o/s suspension damaged.....replaced front subframe and o/s suspension,also removed steering rack to replace inner tie rod & outer track rod end,howver once all back together i have esp light on dash along with steering column & steering angle issues.
    I stupidly forgot to lock the car whilst the steering rack was disconected from the column and my young son decided to have a "play" in the car whilst in this state so i do not know if the steering wheel has been turned multiple times and knackered the steering angle sensor
    I have the front wheels pointing straight and steering wheel is central so looks correct,however unsure if the scan i have done relates to steering g85 damaged or just miles out on the degrees.....how can you check on vcds if the angle sensor g85 is working or knackered ? All i can find on ross tech is the procedure to recalibrate but i got errors when playing on the vcds,looks like i need to find out if the steering angle sender actually works also find out how to see what degrees the steering is registering as i am hoping it is a simple job like rotating the steering wheel by un-doing the steering rack again and not sommat costly now knackered I have not touched the steering wheel inside the car but have had it off at the rack so had "free play" on the wheel......even more if my lad thought it was like being on a ride at the funfair lol,any suggestions much apreciated please and any info regarding the b8 platform steering angle sensor as to if it can get damaged like earlier cars with clock spring thanks daz.
    The full scan done below is holding these faults after the repairs and i also tried deleting dtc's multiple times but just come straight back,thanks guys.
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUZZZ8K4AA132341 License Plate:
    Mileage: 94320km-58607mi Repair Order: a4 avant scan 2
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
    VIN: WAUZZZ8K4AA132341 Mileage: 94320km/58607miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAGA) Labels: 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
    Component: R4 2,0L EDC H22 9096
    Revision: 25H22---
    Coding: 12194012232503080000
    Shop #: WSC 00561 210 181929
    ASAM Dataset: EV_ECM20TDI03L906022NN A02011
    ROD: EV_ECM20TDI03L906019AL.rod
    VCID: 7EF9F619E10C4DEEE9B-802B
    2 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [039] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 94322 km
    Date: 2014.08.13
    Time: 18:29:26
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [039] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Mileage: 94322 km
    Date: 2014.08.13
    Time: 18:29:26
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BB HW: 8K0 907 379 BB
    Component: ESP8 front H04 0020
    Revision: -------- Serial number: --------------
    Coding: 160504
    Shop #: WSC 06335 000 00000
    VCID: 7AF1FA09F52461CED53-802F
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 94322 km
    Time Indication: 0
    Date: 2014.08.13
    Time: 18:30:46
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x07A2
    Hex Value: 0x001C
    Hex Value: 0x239E
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0327
    Revision: 00002001
    Coding: 033200
    VCID: 81030DE518F2B216149-80D4
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    No fault code found.
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
    Component: KLIMA 3 ZONEN H08 0171
    Revision: D0000000 Serial number: 01110220100714
    Coding: 34240000
    VCID: 76E9EE39C13C05AEB1B-8023
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
    Component: BCM1 1.0 H25 0380
    Revision: 09025001 Serial number: 00000000458608
    Coding: 260050914034AF010001000000001D0D001D07080601014100 0000
    VCID: 3A713A09B5A4A1CE953-806F
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 090210 H05 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 94322 km
    Time Indication: 0
    Date: 2014.08.13
    Time: 18:29:00
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 Q HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0070
    Revision: 11001001 Serial number: 51241004406567
    Coding: 000003
    VCID: 479753FDF656CC261AD-8012
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003EFD0BYA2G
    Coding: 30363435363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 41834DE5D072F216D49-8014
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME4F213A55I
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME4F206678M
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME7C4D1E3E2
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME0150481C9
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME464B49341
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME314E2216X
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90319JB8000DE
    Coding: 000017
    VCID: 3D7B3115A48A96F6B01-8068
    Component: E221 - MFL H02 0010
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 221
    Mileage: 94322 km
    Time Indication: 0
    Date: 2014.08.13
    Time: 18:27:20
    Freeze Frame:
    (no units): 44.0
    Text: 2CFFFFFF91FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFF C0FFFFFFFF
    Fuel Consump.: 650.3 l/100
    Raw, Index/Key Err.: 255 255 000
    Text: 35FFFFFF9A00004A1FFFFFFFFC1FFFFFFFFF
    Angle: 0°
    Time (Months): 781
    (no units): 11.75
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 N HW: 8K0 920 980 N
    Component: KOMBIINSTR. H20 0255
    Revision: 00300000 Serial number: CIZ31982A
    Coding: 2F04100002002600010000
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0105
    Revision: GB600050 Serial number: 5000G102028263
    Coding: 00CF07
    VCID: 50A578A103180B9E4B7-8005
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0125
    Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
    Component: J532_DCDCStab H04 0003
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
    Component: TSG FA H11 0306
    Revision: Serial number: 0000102812005
    Coding: 011002204001410001
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0126712806
    Coding: 013B0622203904400020023680000000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
    Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
    Component: DSP Prem H19 0320
    Revision: 00019001 Serial number: 34835000614202
    Coding: 0203010302
    VCID: 7EF9F619E90C4DEEE9B-802B
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
    Component: TSG BF H11 0306
    Revision: Serial number: 0000102846316
    VCID: 46895EF9F15CD52EE1B-8013
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000430770
    Shop #: WSC 00000 000 00000
    VCID: 346D143197C057BE4FF-8061
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 A
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    Shop #: WSC 06334 000 00000
    VCID: 387520014BA8B3DE637-806D
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 Q HW: 8T2 035 186 Q
    Component: Concert3 DAB H07 0350
    Revision: 00000009 Serial number: AUZ5Z6J1349436
    Coding: 0503008201028D00035B070000
    Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
    Component: Display
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000102854147
    Coding: 010002204001210001
    VCID: 428142E9DD74E90ECD3-8017
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000102854150
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
    Component: FSE_256x BT H39 0600
    Revision: 00000000 Serial number: 00000005159688
    Coding: 0010320
    VCID: 3B7F3F0D7A9E98C68E5-806E
    End
  2. Re: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    May 2013
    lancashire
    ok guys can any of you help with these group 030 - 033 reading through 16 steering control as i cannot get the vcds to do calibration....i notice on 032 i have 800+ degrees on both readings,also in group 033 i have 0.0 for steering angle sensor hardware/software can anybody please advise to what my problem might be as it must be associated with me removing the pas rack from underneath NOTE: i have not had the steering wheel off or messed with airbag squib,however the free play in the steering wheel might also have caused this problem.........any suggestions please
    details below :
    Mileage: Repair Order: group 030 16 steering
    Address 16: Steering wheel (8K0 953 568 F)
    13:32:33 Group 030: Steering Angle Sensor I
    Not OK Steer. Angle Sens. initialized
    OK Steer. Angle Sens. Calibrat. Position
    OK Vehicle standing
    OK Vehicle Ident. Number (VIN)
    Mileage: Repair Order: group 031
    13:34:43 Group 031: Steering Angle Sensor II
    819.09° Steering Angle (Main Controller)
    818.78° Steering Angle (Sub Controller)
    Not OK Qualification Bit (Main Controller)
    Not OK Qualification Bit (Sub Controller)
    Mileage: Repair Order: group 032
    13:35:29 Group 032: Steering Angle Sensor III
    SteerAng n.Init Steer. Angle Sens. Status
    calibrated Steer. Angle Sens. Status (Main)
    Not Learned Steer. Angle Sens. Status (Sub)
    No Steer. Angle Sens. ADS capable
    Mileage: Repair Order: group 033
    13:36:05 Group 033: Steering Angle Sensor IV
    0.0 Steer. Angle Sens. (Hardware)
    0.0 Steer. Angle Sens. (Software)
    4.46° Steering Angle (Internal)
    2550.0°/s Steer. Angle Sens. Turn Rate
  3. Re: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    May 2013
    lancashire
    can anyone help please any suggestions much apreciated thanks
  4. Re: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    Jan 2009
    Kidderminster
    Did you get your problem sorted?
    Looks as a minimum like the basic settings for module 16-steering wheel are needed, this is done under [basic settings - 04] group 001, when complete field 3 (third from left) should say OK.
    If you need more guidance let me know.
  5. Re: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    Nov 2014
    Norway
    dazbo1972: Did you figure it out?
    Have the exact same problem with my 2014 S4 after having the steering column out. This is driving me nuts.
    -acetek
  6. Re: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    Nov 2015
    england
    Problem is resolved? Unfortunately I have the same :/ Can someone help?
  7. Re: can you damage the g85 steering angle sensor on a4 b8 after fitting new rack
    May 2007
    knee deep in clunge
    14 Post(s)
    if you disturb the column when you fit the rack you damage the slip ring its a common fitters error
  1. A3 G85 implausible 00778 steering angle sensor
    By Demo8Dan in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-02-2015, 11:12 AM
  2. G85 fault Steering angle Sensor
    By Pamchico in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2012, 07:51 AM
  3. How to program a replacement ABS Controller & Setup G85 Steering Control Sensor???
    By Tecnic91687 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2012, 10:56 PM
  4. steering angle sensor
    By dubber dude in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-01-2011, 08:45 PM
  5. steering angle sensor
    By cass62 in forum Golf MK5 - 2004 - 2009
    Last Post: 12-04-2010, 11:05 PM
