Thread: Golf TDI losing power steering fluid
  1. Golf TDI losing power steering fluid
    Apr 2007
    I have a 53 Golf TDi which developed a grinding noise when I turned the steering wheel at very low speed. It was impossible to think about driving it. I looked for any answers and someone mentioned the power steering fluid (in the green topped bottle under the bonnet). Mine was way below the 'min', so I got some from the garage which he stated was for my car. Anyway, the grinding stopped and I thought 'Brilliant - its fixed it'. But the grinding came back after one day and doing just 20 miles or so. I looked at the fluid and it was back below the 'min' again. I have also noticed a sort of 'wheezing' sound while I drive. Could this be connected? Does anyone have any ideas on what would be causing the grinding/loss of fluid/wheezing, Much appreciated, Bengo
  2. Re: Golf TDI losing power steering fluid
    Pembrokeshire
    22 Post(s)
    if your steering fluid was low, you topped it up, then the next day it was low again, then you have a leak. it might be leaking into the steering rack boots so you don't actually see a leak anywhere, or it could be leaking somewhere else. either way its leaking and thats why the fluid was low. low fluid will cause noises and a lack of assistance as it draws air into the system. fix the leak and the problem will go away.
  3. Re: Golf TDI losing power steering fluid
    Apr 2007
    Thanks zollaf. I replaced the steering rack in the end. Got a second hand one and a mate to fit it. Fingers crossed, should be fixed. Bengo
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Please Help Golf GT TDI 115, Losing power
    By b1ggz in forum Golf MK4 - 1999 - 2004
    Last Post: 22-03-2010, 07:41 PM
  3. Please Help VW Golf TDI losing power
    By MickyC8 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2009, 09:52 PM
  4. Loss of power steering fluid in A3 TDI
    By michaelab in forum Audi A3 - Archive Topics
    Last Post: 08-08-2007, 04:31 PM
  5. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
