Thread: Injector readings
  1. Injector readings
    Feb 2017
    Rochester
    Hi all
    I’m getting these injector readings at 1600rpm. Are they correct?
    My torsion value is -3.43 @ 1600rpm.
    I have a shake/wobble at 1600rpm.
    Also at 1200 rpm but not quite as much.
    Feels like engine shake/wobble. I get a slight wobble all the way through the Rev range.
    Are my injectors wrong or is the wobble due to the torsion value?
    Many thanks in advance
    Rob
  2. Re: Injector readings
    2019 Post(s)
    Those readings are fine but ignore the +/-2.88mg spec, that is a load of ********, anything over +/-1mg is an indication of trouble. Your Torsion value is way too high, which engine? When we do a PDI TDI cam belt I will not accept anything more than 0.50 and stand on the techs head until he gets it right.
  3. Re: Injector readings
    Feb 2017
    Rochester
    I have the 2007 bre engine. Where is your garage? I’d be prepared to travel to get this sorted.
  4. Re: Injector readings
    2019 Post(s)
    Nottingham, rather a long way for a cam belt.
  5. Re: Injector readings
    Feb 2017
    Rochester
    Depends if all the mechanics around you are useless. that’s a bit unfair but I’ve been too several “Audi specialists” in my area and one of them didn’t even know what I was talking about when I said torsion value.
    Does everything need to come off like you do when you change a cam belt or does just the top cover come off to access the top cam.
    I’m seriously considering travelling up. If it solves my issue. Can make a trip of it.
  6. Re: Injector readings
    2019 Post(s)
    It’s just about a days work, my lad Matt is pretty hot on belts but we don’t rush or take pleasure in doing a job quickly, to be honest we charge less than the hours it takes. Private Message me the REG and I will price it up.
  1. Please Help Injector readings
    By Sully53 in forum The Commercial Range
    Last Post: 21-01-2019, 12:20 AM
  2. Injector readings. HELP
    By mickdobson1 in forum VCDS - Help Requests
    Last Post: 06-01-2017, 05:21 PM
  3. Please Help Touran 2.0 TDI faulty injector wiring loom and now possible injector fault
    By bigdaddysi in forum Touran - Sharan - Caravelle
    Last Post: 28-10-2013, 07:13 PM
  4. Please Help Help With Audi TDI Smoking on startup and bad injector readings
    By nokia_aid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-02-2012, 08:14 PM
  5. TDI 1Z MAF readings?
    By bobskitdi in forum Golf MK3 - 1993 - 1999
    Last Post: 27-01-2010, 09:08 PM
