Hi all A4 owners
I have just bought and used VCDS for the first time on my A4 3.0 tdi, I have replaced the V159 temp flap and have now deleted the DTC error so How do I do the adaption ?
I will give it a day or two and check again for error codes, in the mean time can anyone please comment on the other codes and also point me in the right direction to find out what the other items are such as Priority, frequency, counter etc and how to interpret them.
Really appreciate any help so I can learn.
Roger
Thursday,07,August,2014,17:11:17:24301
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ8E38A046832 License Plate: WF57 ETU
Mileage: 106990km-66480mi Repair Order: 1
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E38A046832 Mileage: 106990km/66480miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 N HW: 8E0 907 401 AL
Component: 3.0L V6TDI 000SG 0050
Revision: --H04--- Serial number: XXXXXXXXXXXXXX
Coding: 0011911
Shop #: WSC 06325 000 00000
VCID: 2A5D7E6785A1C44EE53-807F
3 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 107
Reset counter: 255
Mileage: 83981 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 819 /min
Torque: 39.0 Nm
Speed: 0.0 km/h
Voltage: 14.06 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 102613 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 903 /min
Torque: 89.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 24.9 %
Temperature: 13.5°C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 102613 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 903 /min
Torque: 89.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 24.9 %
Temperature: 13.5°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004425
VCID: 2E557277B949A86E39B-807B
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6CD1B87F1CD51A7E57F-5172
2 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00001
Shop #: WSC 06325
VCID: 3D77453B372F43F6B01-4B2A
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0036M0G9EBJE
Coding: 0031612
VCID: 3B734B237A3B4DC68E5-806E
Subsystem 1 - Serial number: 6332DRB4058AC99A3
Subsystem 2 - Serial number: 6342DRB40589D1AF2
Subsystem 3 - Serial number: 6352ARB402A249F9X
Subsystem 4 - Serial number: 6362ARB402A250B2F
Subsystem 5 - Serial number: 63729RB402A663C9V
Subsystem 6 - Serial number: 63829RB402A66849T
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 33
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02011
Shop #: WSC 06325
VCID: 418F39CB4BD72716D49-4B2A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 982 M HW: 8E0 920 982 M
Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007418
Shop #: WSC 00667 210 03906
VCID: 3879542F480D66DE637-5154
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007418
VCID: 3879542F480D66DE637-5172
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E HIGH EU H74 0650
Revision: 04S Serial number: AUZBZ7G1140364
Coding: 0301117
VCID: 326D6607AE718C8E5D3-5190
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 122
Time Indication: 0
Date: 2012.08.08
Time: 08:21:37
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Time Indication: 0
Date: 2014.07.13
Time: 19:37:20
Freeze Frame:
Mileage: 655350 km
Count: 2107
Clock: 18:27
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 79
Time Indication: 0
Date: 2012.08.04
Time: 11:21:17
Freeze Frame:
Mileage: 655350 km
Count: 608
Clock: 20:32
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBD33B6399DB9D46DE5-5154
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CQ
Component: Komfortgerát T3B 4236
Coding: 06895
Shop #: WSC 06325
VCID: 820D76C78E517C0E0D3-4B2A
Subsystem 1 - Part No: 8E2959802F
Component: Tőrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tőrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0606
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301117
VCID: 326D6607AE718C8E5D3-51AE
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 122
Time Indication: 0
Date: 2012.08.08
Time: 08:21:37
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Time Indication: 0
Date: 2014.07.13
Time: 19:37:20
Freeze Frame:
Mileage: 655350 km
Count: 2107
Clock: 18:27
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 79
Time Indication: 0
Date: 2012.08.04
Time: 11:21:17
Freeze Frame:
Mileage: 655350 km
Count: 608
Clock: 20:32
