Thread: Leaking from fuel filter lid
  1. Leaking from fuel filter lid
    Sep 2012
    South of BC
    2010 Audi A3 TDI
    I just replaced the fuel filter, VW 3C0 127 177 with a Mann PU-825-X and it leaks. I put in the new O-ring, carefully. I was extra, extra careful as I tightened down the lid to the filter housing. I hand tightened the torx bolts in a star pattern so I wouldn't warp it, but it still leaks. So I put the old fuel filter back in, figuring the filter might be incorrect, but leaks too.
    I know that the lid doesn't have a gasket but I am thinking that might take car of the leak, but it is a band-aid fix.
    Mine was the single hole type of filter. I was rather paranoid doing this so it wouldn't leak. I tightened the bolts down in a star pattern in an incremental manner so the lid would seat properly.
    The O-ring I double checked to make sure it was not twisted and sat properly.
    I went back in and put back the original filter and it leaked, so I don't know what gives.
    I wonder if it is possible to apply a gasket between the two metals to make a perfect seal against this leak?
    I wonder if anyone has done this mod. before?
    I hate to haveto go to the ******* for this rather simple DIY. Apparently it is not so simple, at least for me.
    Old filter on right, Mann filter on left.
    Any ideas?
  2. Re: Leaking from fuel filter lid
    wakefield
    Take it apart again,lightly coat the seal in oil or vaseline and refit.Done loads of these and it often helps,also make sure you haven't warped the lid slightly when prising off!!
  3. Re: Leaking from fuel filter lid
    Sep 2012
    South of BC
    Quote Originally Posted by panscrub View Post
    How can I tell its warped? I've looked at it and it looks perfect.
  4. Re: Leaking from fuel filter lid
    46 Post(s)
    Can I ask why you didn't buy a genuine one?
  5. Re: Leaking from fuel filter lid
    Sep 2012
    South of BC
    Problem solved. In my original post I mentioned that I hand tightened the bolts. I hand tightened because I didn't want to warp the cover.
    I tightened to a little less than 5nm (still a little paranoid) and didn't go the full 5nm.
    No leaks to report.
    I am a little surprised no one caught my mistake.
  1. Please Help Leaking boot lid
    By barmx043 in forum Jetta MK3 - 2005 - 2013
    Last Post: 11-02-2014, 10:26 PM
  2. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  3. new to Seat!!! - fuel filter leaking :(
    By leighmagill2 in forum Ibiza - Cordoba
    Last Post: 05-11-2012, 11:56 PM
  4. Leaking saloon boot lid
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-09-2010, 06:43 PM
  5. Please Help Polo Air Filter - How do I remove the lid??
    By polotouran in forum Polo - Derby - Lupo - Fox
    Last Post: 23-06-2008, 08:01 PM
