Thread: Airbag and parking brake faults Advice or info please
Results 1 to 10 of 10
  1. Airbag and parking brake faults Advice or info please
    Aug 2014
    Belfast. Northern Ireland
    Hi i'm new to this forum and have been trying to look through but thought it might be easier to post a thread. My Daughter just got herself a (new) 2007 Passat lastweek there was a few things needed sorted so my brother got a mechanic that works for him to go over it and make a list of things that would need sorted which ended up being more than we thought, a new flywheel, clutch, Timing belt tyres, pads all round etc etc but the air bag light was on and the parking brake fault was coming up' so they put it onto their Snap on computer thing and there is a fault code that couldn't be reset ( 01588 Igniter for head - airbag drivers side ( N251) upper limit reached ) so was wondering if anyone could point us in the right direction as he said that it would maybe need a vag com software to tell the exact problem as there is several different airbags fitted?
    Also the parking brake fault is coming up on the car but the computer wont pick up on anything even after a couple of scans.
    So any help would be brilliant as she (we) just couldn't afford to take it to a main dealer at the minute.
    Thanks in advance David
  2. Re: Airbag and parking brake faults Advice or info please
    Sep 2008
    SE London
    For parking brake fault light coming up on dashboard: are both NSR and OSR motors operating? Llisten for each as you operate the EPB button. If so, then the fault maybe the EPB switch itself -- there is an upgraded replacement available at dealer spares
    For the airbag light, it might just need re-setting. Get a VCDS Autoscan and post here? Locator at:
    VWAF User Location Map - VCDS - Google Maps
  3. Re: Airbag and parking brake faults Advice or info please
    Aug 2014
    Thanks for your help RichardSEL I am pretty sure they are both operating but will check, as for the airbag problem is that link which there is a member close to me members of this forum that have the vagcom scanner that can sort the problem and if so would I just send the a pm to arrange etc.?
    Thanks again
  4. Re: Airbag and parking brake faults Advice or info please
    Sep 2008
    SE London
    Depends what details your nearest user has stored. But a PM would at least get there. If you look on the user's Username in here (handle) they may also have an e-mail address listed/option to send an e-mail
    The Autoscan would give more details about your listed faults, and subject to controller when that fault last occured. Best to delete all faults then scan again in a week or so to see what's returned. If you don't have dates stored that's the best way to see what faults are current as against what's historic
    Good luck!
  5. Re: Airbag and parking brake faults Advice or info please
    Aug 2014
    Thanks again Richard
  6. Re: Airbag and parking brake faults Advice or info please
    Aug 2014
    Richard I checked today and it seems that both sides are braking
  7. Re: Airbag and parking brake faults Advice or info please
    Aug 2014
    Also meant to ask, would I have to go to the VW main dealer to get the upgraded switch
  8. Re: Airbag and parking brake faults Advice or info please
    Sep 2008
    SE London
    It may be on e-Bait but dunno what quality. Part number 3C0 927 225 C REH for £28.08 inc VAT.
    It's easy to change by removing driver side fuse panel then pushing the switch out from back,
    first freeing up the plastic locator tabs.
  9. Re: Airbag and parking brake faults Advice or info please
    Norfolk
    The airbag fault is probably the connector under the seat. Common fault on these. Cut out connector and join wires with solder or glue/crimp connectors. reset airbag light. Job done.
    The epb fault is often a sign that one or more motors is getting lazy/seized. Replace the switch first as it's the cheapest option.
  10. Re: Airbag and parking brake faults Advice or info please
    Aug 2014
    Thanks Lads for the help and advice much appreciated
  1. RE passat b6 + parking brake + esp + abs faults
    By jeepster1961 in forum VCDS - General Questions
    Last Post: 10-10-2013, 02:31 PM
  2. 2005 Audi a4 B7 airbag faults!!!!!! Help!!!! please
    By Craig1989 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-06-2011, 07:36 PM
  3. info anyone with a vr6 abs or air con faults
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 14-08-2010, 03:19 PM
  4. 2008 A6 MMI and Parking Brake Faults
    By MClarke in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-08-2008, 02:26 PM
  5. New Passat - Parking brake system fault warning - Advice please
    By jarnelljones in forum Passat - Archive Topics
    Last Post: 05-09-2007, 07:41 PM
