Thread: APS RETROFIT a6 4f reverse camera instal with Kufatec loom MMI 2g
  1. APS RETROFIT a6 4f reverse camera instal with Kufatec loom MMI 2g
    Feb 2010
    bluntisham cambs
    Hullo,
    embarking on another retro fit exercise to give me something to do.
    I have purchased a new cam + boot trim from Audi, the Kufatec 2G loom, and I have a module 4L0 910 441 A, I believe this is from a Q7 but the build date is 01-2007 and mine is 04-2008 so I'm hoping it'll be a straight fit?
    The kufatec loom is pretty vague and in German, can't seem to get the English PDF from kufatec, and yes I did purchase from them but all the numbers I put in still say no, the google translate I got has pointed me to the front right under dash for can 14 hi/lo, but not really which plug, I've had a good mooch, and all still seems vague. There is a long plug behind the end dash trim with purple lock and what seems to be a blanker, and also the only other thing I can find is the control module under the dash, also has a midi fuse attached to it.
    wanted to do a rough set up before pulling mine apart to make sure the module is compatible,
    as ever, your thoughts and suggestions will be greatly appreciated.
    A6 C6 4F
    MMI 2G high
    factory fitted rear sensors and visual display unlocked
    kufatec fiscube dtv
    retro fitted control head with fBAS input
    Dave
  2. Re: APS RETROFIT a6 4f reverse camera instal with Kufatec loom MMI 2g
    Jul 2013
    76 Post(s)
    The Purple connector is the can-bus connector the 14 H and 14 L connections are in this.
    Dan
  1. Please Help Reverse Camera (RVC) Help
    By vaslam1986 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2017, 09:48 PM
  2. Reverse camera issues
    By gtime in forum In Car Entertainment
    Last Post: 25-03-2014, 03:21 AM
  3. reverse camera ..... thoughts
    By billy_m_1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-09-2013, 04:08 PM
  4. Help: Fitting reverse camera to B6 Passat
    By gwynn007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-07-2010, 11:26 AM
  5. Reverse Camera
    By topgunmatt in forum Golf MK4 - 1999 - 2004
    Last Post: 18-08-2009, 10:12 PM
