Thread: Can a faulty engine speed sensor cause excess smoke?
  1. Can a faulty engine speed sensor cause excess smoke?
    Feb 2010
    uk
    As per title, can some explain if a faulty sensor can cause excess white smoke, and if so how?
    i mean what is the technical explanation?
    i know I have oil consumption issues, and I am topping about a litre every 500 miles.
    however recently the smoking was particularly bad at idle, during gear changes and when overran usually coming off motorway. I developed tell tale crank position sensor issues with stalls, cutting out EPC light and VCDS confirmed the engine speed sensor,
    I have just replaced it, cleared codes, driven fine for 2 days and the small miracle of a lot less smoke- I just can't understand why? Is it a coincidence or is it linked.
    the car did have a poor service record prior to my ownership and I had accepted bad internals...perhaps it's too wishful to think oil consumption will get better too...
    Audi A4 2002 1.8T Quattro Avant
    No modifications
  2. Re: Can a faulty engine speed sensor cause excess smoke?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Did you use VCDS to scan car? There may be further codes stored. You haven`t overfilled the oil have you?
    Check breathers etc. as a check.
    With the oil its burning, there is a chance the Cat is contaminated and possibly Lambda issues. Can you get an emission test to check? If all okay it should pass a test no problem.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Can a faulty engine speed sensor cause excess smoke?
    Feb 2010
    uk
    Quote Originally Posted by Alan02 View Post
    Vcds showed engine speed sensor fault; now that it has been replaced there is a massive improvement in amount of smoke.
    prior to the sensor failing there had already been an oil consumption issue. I am suspecting now that the engine must have been running rich due to the sensor fault and that was causing the severe smoking and oil breakdown ( exhaust is very black).
    i have deleted the codes ans rescanned and the only one that comes up is coolant sensor at radiator outlet( which I have previous replaced with an aftermarket sensor).
    a few weeks ago I cleaned out all the breather hoses and pcv valve; I am thinking about pcv deletion but haven't got the confidence to do it yet.
    i haven't done enough miles yet to judge the oil consumption, but there is less smoke since replacing engine speed sensor so I assume less oil burning too.
    It is due for its Mot in a month anyway so emissions will be tested
    No modifications
  1. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  2. will faulty speed sensor affect auto box?
    By charliebucket in forum Golf MK3 - 1993 - 1999
    Last Post: 04-09-2011, 10:31 PM
  3. Transmission Speed Sensor Faulty (Multitronic) A6 C6
    By boltona in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-04-2010, 11:25 PM
  4. excess smoke from exhaust - head gasket?
    By zidane in forum Archive posts
    Last Post: 29-10-2007, 11:20 PM
  5. excess revving at start up and smoke
    By kevin123 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2007, 01:29 PM
