Thread: Rear Axle Bush Replacement
  1. Rear Axle Bush Replacement
    Aug 2008
    Somerset
    Hi Guys
    Has anyone done the rear axle bush replacement on the A6?
    My car has just passed 156,000 and the back end is becoming sloppy when loaded.
    Any pointers greatly received
  2. Re: Rear Axle Bush Replacement
    7 Post(s)
    Quite an easy job.
    Carefully mark where the existing brackets are.
    Support the beam with a jack.
    Undo the big through bolt.
    Remove the three bracket bolts and remove bracket.
    You will need to apply quite a lot of force to the fixings so make sure the car is very well supported. Do one side at a time.
    You will also need to persuade things to go back where they came from with some force as well.
  1. Question Rear Axle Bush
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2011, 08:49 PM
  2. Question Rear Axle Bush
    Last Post: 21-03-2011, 11:30 PM
  3. Rear Axle Bush Replacement
    By BoraTDI in forum Bora - 1998 - 2005
    Last Post: 28-07-2010, 01:28 PM
  4. Rear Axle Bush Replacement in Progress
    By waaarp in forum Golf MK4 - 1999 - 2004
    Last Post: 06-05-2010, 08:03 AM
  5. How To Rear axle bush's
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-09-2009, 01:23 PM
