Thread: 5 speed to 6 speed gearbox swap - help
  1. 5 speed to 6 speed gearbox swap - help
    Feb 2009
    Looking to swap my 5 speed gearbox (A4 Cab 2.4 BDV) for a 6 speed.
    Have correct gearbox (GBX) and gear stick/linkage - came from a 2004 Cab engine is already installed in my car!
    Cross support is the same for both models so can use mine
    I have the gearbox support - was on the 6 speed one.
    Starter is the same for both.
    Clutch slave is the same
    DMF and Clutch appear to be the same.
    Would I need to replace the gearbox support frame - part numbers are different but any photos I look at appear to be the same?
    Do I need to get a new pipe from the clutch master cylinder to the slave cylinder?
    Am I missing anything else?
    Thanks,
    W.
  2. Re: 5 speed to 6 speed gearbox swap - help
    134 Post(s)
    2004 Post(s)
    So you have replaced the ENQ/EBL 012 transmission for a GDX 01X series, not a GBX....
    You should use the 8E0 399 105 HR rear support.
    The big problem you are going to run into is you will need the cats from a six speed
  3. Re: 5 speed to 6 speed gearbox swap - help
    Feb 2009
    Thanks Crasher,
    So my gearbox support should work (I believe the gearbox I got still has the rear support attached!)?
    Would you know what the difference is between the 5 speed and 6 speed cats? I assume it is an exterior design difference to fit the cat around the box since the engine is the same.
    Much appreciated,
    W.
  4. Re: 5 speed to 6 speed gearbox swap - help
    134 Post(s)
    2004 Post(s)
    Yes it is the exact correct box code for that car with that engine when six speed. Yes it is the shape of the cats as the 01X box is wider. You may have to alter the ECU soft coding for 6 speed, not sure.
  5. Re: 5 speed to 6 speed gearbox swap - help
    Feb 2009
    Hi All,
    Just to say conversion is now complete - have a 6 speed gearbox in my 2.4 cab and it is sweeeet - far superior drive than the 5 speed, 1st to 2nd does not experience the same loss of power I had before and in 6th at 120kmh car is so much quieter - I don't feel that I need to "change gear" . In the end the only part that was needed was the clutch pipe - (the used 6 speed came with the mount still attached and the clutch slave cylinder). Did get an Aluminium 6 speed gear knob to replace my one on ebay - cost €50.
    I got the gearbox, and lever system and the drive shafts with the engine so if you want to do it you need to get these. To get the cats to fit only the mounts needed to be re-welded not too big job.
    Anyway, thanks Crasher for the info,
    W.
  1. Gearbox replacement 6 speed for 5 speed
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-07-2014, 12:39 PM
  2. Reset Trip Computer results in speed warning at low speed after start up ?
    By davemeysner in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-06-2013, 06:18 PM
  3. Replies: 19
    Last Post: 02-12-2012, 09:47 PM
  4. How To VW Caddy Van gearbox. 5 speed or 6 speed
    By free2go in forum The Commercial Range
    Last Post: 18-11-2008, 03:35 PM
  5. Can you replace 4-speed gearbox with 5-speed? Golf ryder 1.4
    By Finjamin in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2008, 11:31 PM
