Thread: Radio reception
Results 1 to 10 of 10
  1. Radio reception
    Jan 2010
    peterborough
    Over the last couple of weeks the radio reception in my C7 has been getting worse to the point where now I can't listen to DAB as it drops every couple of minutes and I can't even maintain an FM reception and TMC rarely works.
    I've tried resetting MMI and re scanning but it made no difference.
    Is there any antenna connections I can check myself before I book it in to the dealers?
  2. Re: Radio reception
    Mar 2013
    Reading
    31 Post(s)
    Quote Originally Posted by starsky365 View Post
    Interesting that one!
    I have the same problem (but it is persistent) to the point where I asked Audi to look into it during the service. No luck however. The irony is, when the signal goes, the entire 'radio' is frozen...
    The only thing they did in the service was to disable auto retune or whatever that option is called and told me that it should not freeze at least any more (yes, now I can switch to FM when it happens) but, IMHO, not how DAB should work! Specially as I never had a similar problem with DAB in the Passat I previously had.
  3. Re: Radio reception
    Jul 2014
    Ain't just confined to Audi, I have Jaguar XK8 with DAB. it is absolutely useless I'm sure the issue lies with DAB radio.
  4. Re: Radio reception
    Apr 2009
    Surrey
    183 Post(s)
    My first point of investigation would be either the connection between the window element (rear window on saloon, passenger rear side window on Avant) and the cable and the aerial amplifier. Either would give the reception problems described here
  5. Re: Radio reception
    Jan 2010
    peterborough
    Ok it's an avant, any chance you could show a
    Pic? Not sure where amp is
  6. Re: Radio reception
    46 Post(s)
    If its under warranty don't check/touch anything. Let them sort it!!
  7. Re: Radio reception
    Jan 2010
    peterborough
    Yeah I know it's just a pain as I use the car for work so end up having to book it in weeks in advance to get a courtesy car then can only stay local as it has to be back same day
  8. Re: Radio reception
    Jul 2014
    Chesterfield
    16 Post(s)
    Quote Originally Posted by berlintaxi View Post
    Not sure about that, I travel all over and only lose DAB signal in the borders of Scotland for a short time and the odd spot in the Peak District. Never lost signal or had any other issue with DAB anywhere else. That was in both a 2011 C7 A6 and a 2011 Jaguar XF I just sold.
    I would definitely get it in under warranty and have it looked at.
    Q7, S-line, Graphite Grey, full leather, 21 inch titanium wheels
  9. Re: Radio reception
    Jun 2014
    Chesterfield
    It may sound daft, but do any of you happen to have the TV tuner option fitted to the car?
    This dropping out of sound was/is an issue on the jaguar/land rover systems when TV tuner was fitted. Its still an issue on my range rover now. Apparently the tuner is constantly scanning and receiving in the background, but a change in one of the broadcast signals has caused these TV tuner systems to "hickup" causing a second or so of silence at random intervals. Doesn't matter whether you are listening to dab, FM or something else. Temporary fix was to set the TV tuner to think it was not in the UK.
    http://www.pistonheads.com/gassing/topic.asp?t=1331160
  10. Re: Radio reception
    Jan 2010
    peterborough
    Nope no tv tuner; I'll have to book it in
    Sent from my iPad using Tapatalk - now Free
  1. Re: radio reception
    By wally59 in forum In Car Entertainment
    Last Post: 26-02-2014, 01:22 PM
  2. FM radio reception
    By burkey1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-11-2010, 12:53 PM
  3. AM radio reception
    By dandam in forum Audi A3 - Archive Topics
    Last Post: 03-09-2008, 11:37 AM
  4. poor radio reception on aftermarket radio
    By pukrik3@pukrik3 in forum New Member Introductions
    Last Post: 23-07-2008, 09:21 AM
  5. Radio Reception
    By granger in forum Touran - Sharan - Caravelle
    Last Post: 02-03-2008, 01:08 PM
