Thread: MMI Control
  1. MMI Control
    Sep 2007
    Does anyone have or perhaps have access to a schematic of the control unit next to the electronic brake button.
    The large main button on my unit has some kind of fault. It does not enable the scrolling function, however if pressed it will select.
    Any help on this would be great
    thanx
  2. Re: MMI Control
    May 2007
    knee deep in clunge
    14 Post(s)
    If you mean wiring diagram then it will only show you feeds in and out and not the internal circuit,most if not all soft touch mmi control faults i have seen have been a result of fluid spillage and warranty claims are rejected on this basis as audi ask for all mmi controls back to inspect.Have you tryed to manually reset the mmi as per owners hand book if tht fails and there are no faults in the most network then its a new control pad,i think there about £200 and can be replaced without recoding via vagcom.
  3. Re: MMI Control
    Sep 2007
    yep, seems like fluid - not everything goes better with coke !
  4. Re: MMI Control
    May 2007
    knee deep in clunge
    14 Post(s)
    always seems to be coke
  1. A6 climate control / air con
    By Oakstedge in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-07-2009, 10:14 PM
  2. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  3. MMI and Ipod control
    By Lee_m in forum Audi A4 - Archive Topics
    Last Post: 22-06-2007, 07:51 PM
  4. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
  5. Cruise control
    By Jimchoc in forum Passat - Archive Topics
    Last Post: 12-09-2006, 08:28 PM
