Thread: Rear Disk Wear Limit
  1. Rear Disk Wear Limit
    Jun 2006
    Hi guys,
    Having my alloys refurbished today. Looked at the disks and pads when wheels off.
    Fronts good as expected as changed them a while back.
    Rears have about 6mm on the pads, disks not scored but they have a lip, on outside about 1mm, rear about 2mm.
    I guess I should be replacing disks next pad change?
    Will find out then if larger disks need that special tool mentioned in a recent post !
  2. Re: Rear Disk Wear Limit
    Jun 2006
    Found answer, minimum thickness on mine (1KW) is 20mm. New they are 22mm.
  1. A3 rusty rear disk
    By Kar Krazy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-05-2013, 12:58 PM
  2. Question Brake disk wear limits on 1.9 TDI Quattro Avant
    By GeorgeE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2011, 10:54 PM
  3. Brake disc wear limit
    By stevemr in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2011, 09:17 AM
  4. Rear Disk Bracket
    By S-lineSingh in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-08-2010, 03:48 PM
  5. Brake disk wear
    By leon_richard in forum Leon
    Last Post: 12-07-2010, 05:01 PM
