Thread: new mods help
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. new mods help
    Jul 2007
    yorkshire
    i need help???????? which mod will give best increse in performance.
    1=new exhaust manifold £200.00 aprox (ebay say about 25bhp increase)
    2=s/steel exhaust system £300.00(3-4bhp increase)
    3=jkf front mount intercooler £300.00(3-4 bhp increase)
    are these figures about right or not please correct me if wrong
    AND VERY IMPORTANT WILL BE STOCK ENGINE PARTS TASKE THE STRAIN OF THESE PARTS. I know i need upgraded acuator valve(forge) and i have up rated brake pads but what about the rest..????
    FINALLY======== the scorpion exhaust system i was looking at above is that a good make i cant find ANY ONE else who sells them i found sebring make just a back box but that costs about £270.00 seems silly jsut for increase in noise at that price
  2. Re: new mods help
    Sep 2007
    swindon
    Scorpion are okay, i have been looking into a new exhaust system for my 1.8t, the one i am swayed toward is the powerflow system. they look to be good value for money as well as giving a considerable more increase in power to other manafacturers
  3. Re: new mods help
    Feb 2007
    UK (London)
    Manifold may flow better but with a K03 you will loose bottom end power so unless you are going BT dont bother.
    Exhaust system is a good idea.
    FMIC will not gain any power you may even see a drop in 1 psi of boost but will keep the temp low and so prevent heat soak but once again if you are not going BT it not worth doing.
    What I would do first is have the car remaped as this will see big gains.
    Stock engine will take up to 330bhp before internals are needed.
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
  4. Re: new mods help
    Sep 2007
    stone,staffordshire
    i heard (a wise man once said) every 10 degrees you reduce the charge temp by you will gain approx 2-3% power any engine any fuel. with a fmic you usualy shorten pipework too which normally compensates for any pressure drop. ( im a big fan of intercoolers ) + cooler air means you can run more advance/ boost. just my 2 pennys worth
  5. Re: new mods help
    Jul 2007
    yorkshire
    How much are the powerflow systems?? and what power increase would i expect??
    next question does anyone find that there audi is bloody loud abov 80mph?? and im mean genral noise not fault on car it like bin in a tornado!!!!!!!! it the loudest car i driven. and would coilover suspension kits make a big diff?? because to be onest the handling of my car even though it a sport model with stiffer suspension it sooooooooooooo c**p!!!
  6. Re: new mods help
    Feb 2007
    UK (London)
    You may need new door rubber.
  7. Re: new mods help
    Jul 2007
    yorkshire
    and i thought id had my car remapped from the chip i got of f flea bay
  8. Re: new mods help
    Feb 2007
    UK (London)
    Quote Originally Posted by mrjolly View Post
    But with such a small turbo and larger pipe work he is unlikley to see the gains unlike a larger turbo.
  9. Re: new mods help
    Feb 2007
    UK (London)
    Quote Originally Posted by A4 TURBO View Post
    Missed that bit so as stated the exhaust would still be the best option and maybe upgrade the DV to a TT225 unit or go for an aftermarket unit like APR R1 as the DV's tend to fail after a remap.
  10. Re: new mods help
    Jul 2007
    yorkshire
    how much for uprated turbo and what part no is it cos the turbo i got on mine about knackered....the acuator rod loose and the shell got slight crack on it. What bhp increase whould i get on turbo uprgrade
  1. Audi 80 2.0E mods
    By walk_aw in forum 80 - 90
    Last Post: 03-09-2007, 09:20 PM
  2. What mods would you do?
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 11-06-2007, 04:01 PM
  3. Air Conditioning Mods
    By Andy B in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-04-2007, 09:01 AM
  4. Engine mods on A3
    By Pitty the fool in forum Archive posts
    Last Post: 17-12-2006, 09:16 AM
