Thread: Exhaust manifold stud snapped off !
  1. Exhaust manifold stud snapped off !
    Sep 2007
    Telford area
    Can someone please give me an idea how to get the remaining stud out of the head. Do I need any special type drill bits and how do I drill it out without wrecking the thread?
    Thanks in anticipation
    Chris
  2. Re: Exhaust manifold stud snapped off !
    Canada
    has the stud broken off or just stuck? a stud extractor should get it out.
  3. Re: Exhaust manifold stud snapped off !
    Sep 2007
    Telford area
    Thanks for the reply ...... It's snapped off flush with the head onzarob. Are stud extractors a generic tool? .... easy to use?
  4. Re: Exhaust manifold stud snapped off !
    Apr 2007
    Lancashire
    If you cant weld a nut onto it, soak the area in penetrating oil and drill/dremmel a small hole so that you can use an easy-out & impact driver.
  5. Re: Exhaust manifold stud snapped off !
    Sep 2007
    Telford area
    Quote Originally Posted by ini View Post
    Thanks ini ...... I have a dremmel ... will a small drill bit that came with it manage it or can you buy tungsten carbide bits to fit? Just a bit worried about drilling into the head.
  6. Re: Exhaust manifold stud snapped off !
    Southampton, UK.
    With a stud extractor, you drill a hole the size you're told, screw the jobbie into the hole. As it's a left handed thread, the more you tighten it, the more it digs in and it'll start unscrewing the stud.
    Similar thing happened to me with a rocker cover bolt. Shat myself, but the extractor saved me!
  7. Re: Exhaust manifold stud snapped off !
    Sep 2007
    Telford area
    Quote Originally Posted by herby0001 View Post
    Thanks for that Herby ...... found a "backstreet" VW specialist and they're going to do it sometime this week for £50 ...... that'll save the underpants .....
  1. stud pattern pcd
    By littlejim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2007, 03:41 AM
  2. engine been stud
    By e6m6a6 in forum Polo - Derby - Lupo - Fox
    Last Post: 08-05-2007, 11:28 PM
  3. Cleaning the Intake Manifold....
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 07:51 PM
  4. Frequently Blown Exhaust Manifold Gaskets-suggestions?
    By U. Lange in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-12-2006, 04:20 AM
