Thread: Priority 1 brake warning light.
  1. Priority 1 brake warning light.
    Mar 2011
    Southwold
    I have been getting a priority 1 warning fault system indicator on the dash for the brakes, and is as the manuals states “This symbol is accompanied by three warning chimes and then the big symbol is then replaced by a smaller one in the top left corner until the fault is rectified”.
    However, within a few seconds of this happening, all red lights go off and it does this ever time, no other fault lights, just brakes, I have plugged VCDS into the car, no faults, pads are good, I have shorted out both fronts pads, no difference, hand brake works fine, it’s not every trip and can do it more than once in a trip, each time it does it, the fault never stays and VCDS shows nothing, fluid is good, servo works fine, car stops as good as ever.
    If I corner really hard to the left I can normally make it happen 1 out 8 times but also happens with all types of driving and if I try the brakes while the fault is active they work fine and fault goes, if I don’t touch the brakes, the fault still goes. Pressing the dash “check button” not fault.
    Can anyone help please?
  2. Re: Priority 1 brake warning light.
    Pembrokeshire
    22 Post(s)
    the thing about cornering wouldpoint me to something that changes whilst cornering and that thing could be the fluid level. is it full, could it take any more, could the sensor be a bit over enthusiastic. maybe work out if its a make or break sensor and either unplug it or short it out and see what happens ?
  3. Re: Priority 1 brake warning light.
    Mar 2011
    Southwold
    the thing about cornering would point me to something that changes whilst cornering and that thing could be the fluid level ?
    That had crossed my mind but as the fluid has its owner indicator ( I think ) I had ruled that one out, however, the level is mid-way between min and max as I change the fluid regularly and saw no point filling up to the top only to suck it out again, thanks for your reply, I will put more in as I do corner to the limit of the tyres from time to time.
  4. Re: Priority 1 brake warning light.
    Mar 2011
    Southwold
    I did just that Zollaf, put another 100ml in and that sorted the fault, I guess it was just at the tipping point for the fault to clear it’s self so quickly, thanks for your help.
  1. ABS warning light & flashing brake light
    By mrbiondi in forum Touran - Sharan - Caravelle
    Last Post: 14-10-2011, 01:47 PM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  4. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
