Thread: vcds fault code
  1. vcds fault code
    Feb 2014
    wilsontown / uk
    I have a fault code on my A3 Audi that won't clear :-1 Fault Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 007 - Short to GroundYet i find no problems with my radio reception.Has anyone had this and/or knows exactly what the cause is??
  2. Re: vcds fault code
    46 Post(s)
    00858 - Ross-Tech Wiki
    Code:
    00858 - Connection; Radio IF Output to Antenna Amplifier: Short to Ground
    Possible Symptoms
        Radio Tuner not working
    Possible Causes
        Wiring/Connectors from/to Antenna Amplifier faulty
    Possible Solutions
        Check Wiring/Connectors from/to Antenna Amplifier
        Check Measuring Value Blocks (MVB)
        Check Antenna Amplifier
  1. MMI VCDS Fault code post flood/software update
    By DieTryin' in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-02-2013, 01:52 PM
  2. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. VCDS Scan Fault Code 01548
    By elPaulio in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-03-2010, 08:09 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
