Thread: 2.5 TDI oil leak from filter
Results 1 to 8 of 8
  1. 2.5 TDI oil leak from filter
    Apr 2014
    Essex
    Hi, my friend has changed his oil and filter and is unable to stop the filter from leaking. He has replaced the o ring seal and tried varying tightness of the filter housing.
    Any ideas?
  2. Re: 2.5 TDI oil leak from filter
    Apr 2014
    Essex
    Forgot to include the oil is leaking from the seal which bulges out once the oil gets hot.
  3. Re: 2.5 TDI oil leak from filter
    Jul 2011
    Norway
    Look for a tiny crack in the plastic upper housing. This part can crack if someone overtighten it
  4. Re: 2.5 TDI oil leak from filter
    Did he use a genuine filter and seal.
    25 Nm
    Use 32 mm socket to loosen and tighten
    Regards Peter
  5. Re: 2.5 TDI oil leak from filter
    Apr 2014
    Essex
    Thanks will tell him to check the plastic housing, not sure if it was a genuine filter / seal.
  6. Re: 2.5 TDI oil leak from filter
    Apr 2009
    Epsom Downs
    Run the engine with the dipstick removed to see if things improve, there may be a crankcase pressure issue.
    Worth strapping some rags around the opening to keep the splashes under control...
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  7. Re: 2.5 TDI oil leak from filter
    May 2007
    Tipp/Cork - Ireland
    Its worth checking to see if the sealing ring has been placed in the correct groove of the filter housing. It should not be directly under the lip of the housing - this happened to me on a different car and the result was the same as you described. Cant find image on internet but this video might help - 2004 Volvo XC90 2.5T FWD Engine Oil Change - YouTube (23min mark). And if this is your problem then you should replace the seal again
    2006 A6 2.7Tdi Quattro Saloon BPP Engine
  8. Re: 2.5 TDI oil leak from filter
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    As dengsx said above - If the O ring is in the correct place, it is impossible for it to bulge up and leak, as there is virtually no gap between the plastic top and the alloy body. If the plastic top was cracked enough for the O ring to bulge, there would be a massive fountain of oil from the crack.
    I suspect either the O ring was not in the correct groove, or not lubricated before fitting, so it has been dislodged as the top was screwed down.
  1. Question Mk3 GTI 16v (ABF) oil Filter Housing Leak
    By richardm in forum Golf MK3 - 1993 - 1999
    Last Post: 28-08-2012, 10:18 AM
  2. Audi A4 1.9 TDI (110) Oil leak and Possible boost leak?
    By officialuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2011, 10:45 AM
  3. Slight oil leak foward of oil filter 1.8T
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-03-2010, 09:44 PM
  4. oil leak near filter
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-03-2009, 07:31 PM
  5. Question Leak from one of the switches/sensors where the oil filter sits
    By DaveX19 in forum Golf MK3 - 1993 - 1999
    Last Post: 30-06-2008, 12:04 AM
