Thread: Raising engine to remove oil sump 1.8 T
  1. Raising engine to remove oil sump 1.8 T
    Jul 2014
    Brighton East Sussex
    Hi I've been told it is possible to undo the engine mounts and raised the engine to drop the oil sump on A4 1.8t cabriolet has anybody done this any help would be great
  2. Re: Raising engine to remove oil sump 1.8 T
    Sep 2008
    6 Post(s)
    2016 BMW i3 REx (80k)
  3. Re: Raising engine to remove oil sump 1.8 T
    london/ UK
    Quote Originally Posted by spartacus 68 View Post
    I don't believe in magic flushes and i cannot be ***** to watch the video till the end, however when the pressure is that low, there is no amount of flushes and magic potions that will restore the engine wear ! I have opened hundreds of engine and many petrol engines looked like that due to cheap *** oil being used just because the spec said it's good enough ! When the oil pressure is that low the big ends are already worn trough...
    1 1 0
  4. Re: Raising engine to remove oil sump 1.8 T
    Sep 2008
    6 Post(s)
    Quote Originally Posted by adamss24 View Post
    I only posted the video as it shows how to loosen and drop sub-frame to access sump bolts. Quite an interesting video none-the-less. The previous owner had used too much sealer when sump was refitted and parts of it were in the oil pick up pipe, no doubt blocking oil recirculation.
    Mechanic flushed engine with degreaser, then ATF, then ran it with cheap oil before refilling. Seemed to be getting engine pressure and cams were fine.
  1. Question Advice....why remove Oil Sump?
    By shanef in forum Golf MK5 - 2004 - 2009
    Last Post: 04-06-2013, 12:17 PM
  2. 8P 1.6 BGU Engine - Oil Change - Necessary to Remove Undertray?
    By keicar in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2013, 11:40 AM
  3. Audi allroad 2.5tdi AKE engine year 2001. oil leak from Sub sump
    By hayabusa67 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-06-2011, 10:11 PM
  4. Oil Leak - How do I remove sump/engine guard?
    By Dan Glibitz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2010, 01:45 PM
  5. How To Remove sump 1.9d 1Y 1996
    By mikeatlofty in forum New Member Introductions
    Last Post: 29-03-2009, 03:57 PM
